uRADMonitor air quality sensors deployed in Bistrita, Romania, illustrating distributed indicative monitoring for spatial air quality assessment.
Commission Implementing Decision (EU) 2026/1208 introduces a harmonised methodology for determining the spatial representativeness of air quality sampling points and using modelling applications under Directive (EU) 2024/2881. Adopted on 9 June 2026, published on 10 June and applicable from 30 June 2028, it creates a practical opportunity to combine reference stations, distributed indicative measurements and atmospheric modelling.
Measurement accuracy is not spatial representativeness
A precise instrument characterises the air at its sampling location. It does not automatically characterise every street, residential district or industrial area around it. Traffic intensity, heating, topography, street geometry and meteorology can produce substantial differences over short distances. Representativeness is pollutant-specific and depends on both concentration similarity and the characteristics of the surrounding area.
Reference stationPollution hotspotPotential similar areaIndicative monitoring pointReference station
Conceptual illustration, not measured concentrations or an official representativeness map.
What the new European framework requires
Article 4 requires an assessment in zones above the applicable assessment thresholds, using measurements, modelling or both. Below those thresholds, assessment is optional. Articles 5 to 8 define the concentration comparison, geographical refinement and mapping process. Article 9 provides for the use of indicative results in air quality assessment, including mandatory use when those results show exceedances of limit or target values. These are obligations on Member States, not a direct obligation for every municipality to purchase sensors.
Article 6: indicative measurements as a spatial assessment method
Indicative campaigns must capture seasonal variation, with measurements distributed across the year (April to September for ozone). Where indicative measurements are the sole measurement method, their number and spatial distribution should capture expected concentration variability as far as possible. Article 6(2) also permits the modelling uncertainty objective in Annex V of the Directive for the pollutant concerned. This is a separate concept from the similarity tolerance below.
Spatial Representativeness Calculator
For comparable annual means or another appropriate metric under Article 5(2), the similarity interval is C ± max(0.15 × C, T_min), where C is the central concentration and T_min is the Annex I minimum for the pollutant. The following calculator implements the numerical test in Articles 6(3) and 7(2), without optional rounding to two significant digits.
Annex I minimum: 2 µg/m³
Green band: similarity interval. Blue: central value. Orange: comparison.
Passing this numerical test identifies a candidate location, not the final spatial representativeness area. Article 5 requires refinement using geographical limits, emission profiles and dispersion conditions. A tolerance is not a measurement uncertainty or a legal limit value. Concentrations must use the same units, pollutant and averaging metric.
From distributed measurements to a representativeness map
1. Inventory reference stations, emission sources, terrain and meteorology. Define the pollutant and assessment metric.
2. Select indicative instruments using documented performance, co-location and a quality assurance plan.
3. Deploy across contrasting traffic, residential, industrial and background environments. Capture representative seasonal conditions.
4. Harmonise timestamps, units and averaging periods. Flag invalid data, document calibration and quantify uncertainty.
5. Compare concentrations, integrate suitable dispersion models and refine candidate areas using expert analysis.
6. Produce pollutant-specific maps, document overlap and gaps and recommend network improvements.
Article 7 applies the same numerical similarity principle to modelled concentrations, using the modelled value at the sampling point as the centre. Independent observations are valuable for evaluating model performance; data already assimilated into a model should not be treated as independent validation. Article 8 addresses mapping and overlapping areas, using a year within the preceding five years or a demonstrated reliable method accounting for interannual variability. Maps are reviewed alongside the regulatory network review and when relevant conditions change.
Five practical applications for environmental authorities
Assess existing stations: identify areas with comparable pollution profiles and distinguish roadside from background environments.
Identify monitoring gaps: investigate districts and corridors not adequately characterised by existing stations.
Temporary campaigns: investigate specific sources and seasonal patterns, with duration and coverage matched to the assessment objective.
Evaluate dispersion models: compare predictions against independent observations at multiple locations.
Plan new stations: use spatial evidence to prioritise locations for further investigation and formal siting assessment.
uRADMonitor: proven experience in spatial monitoring
Distributed monitoring is already an established application of uRADMonitor technology. In Timișoara, mobile MODEL A3 instruments on public transport collected more than 14,000 measurement points along urban routes. In Cluj-Napoca, MODEL CITY supports multipoint monitoring, including the European URBREATH project. In Bucharest Sector 1, more than 100 MODEL A4 instruments demonstrate the scalability of distributed urban infrastructure. Research in Craiova has explored the spatial distribution of ozone. These deployments provide relevant operational experience for projects under the new methodology.
Case study: Cluj-Napoca and URBREATH
MODEL CITY and MODEL A3 bring independently evaluated measurement technology to distributed networks. The uRADMonitor platform provides timestamped data, remote access and historical exports, supporting repeatable analysis and integration with external GIS and modelling workflows.
Direct Local Access | Historical data export
Prepare for 2028: procurement and project deliverables
The 2027 calendar year presents an opportunity to collect baseline information before the application date. A project brief should specify pollutants, site typologies, seasonal coverage, measurement performance, interoperability, maintenance, quality control, GIS exports and documented analysis. Equipment supply can be combined with technical partners specialising in atmospheric modelling and formal environmental assessment.
Further reading and official sources
Commission Implementing Decision (EU) 2026/1208 | Directive (EU) 2024/2881
Indicative measurements and independent validation
Municipal network design
European funding
Build a spatial air quality monitoring project with uRADMonitor
From distributed measurement infrastructure to data integration, uRADMonitor provides the technological foundation for spatial air quality projects. Contact us to discuss the equipment configuration, coverage and technical partnerships required for your project.
Request a technical proposal
