uRADMonitor › Data and API
Environmental data and API
816 sensors online in 43 countries · data since 2013
uRADMonitor stations report their measurements to a global network. You can follow the values live on the map and on the city, radiation and sensor pages, embed them on your website, or access them through the REST API.
Where the data comes fromTerms
Values shown on this website: live map, city, radiation and sensor pages, embeddable widgetsFree to reuse under CC BY 4.0, with attribution to uRADMonitor.
Data from your own units (dashboard export and API)Yours to use.
Data from other units through the APIUnder the API Terms of Service: registered account, free tier for non-commercial display without storing the data in a database, paid tier for commercial applications. Contact us to request access.
Ways to use the data
Authentication
Create a free account, log in to the dashboard and open the API tab. It shows your user ID and your user key. Send them with every call as two HTTP headers:
X-User-id: YOUR_USER_ID
X-User-hash: YOUR_USER_KEY
Your account sees the units you own and the units you were given access to. All calls use HTTPS and return JSON. Errors come back as {"error": "..."}.
Endpoints
Base URL: https://data.uradmonitor.com/api/v1/
CallReturns
GET /devicesYour units, with the latest value (last_XX), a moving average of the latest readings (avg_XX) and the name and unit (param_XX) of every sensor, plus location, status, firmware, hardware and AQI.
GET /devices/{id}The sensors of one unit, with names and units.
GET /devices/{id}/{sensor}Readings of one sensor over the last 24 hours.
GET /devices/{id}/{sensor}/{start}/{stop}Readings between start and stop, given in seconds before now (stop is optional). Use all for every sensor, all-raw for every sensor without compensation, and last as start for the latest record only. Maximum span: 60 days for one sensor, 1 day for all.
GET /devices/{id}/average/{start}/{stop}Daily minimum, maximum and average of every parameter, up to 120 days.
Example, PM2.5 from one unit over the last hour:
curl -H "X-User-id: YOUR_USER_ID" -H "X-User-hash: YOUR_USER_KEY" \
  https://data.uradmonitor.com/api/v1/devices/82000466/pm25/3600
Best practice: read /devices once and use the last_XX fields. Request time series only for the units and intervals you need.
Unit fields
FieldMeaning
idUnique unit ID (8 hex digits). The first byte identifies the model.
timefirst, timelastUnix time of the first and of the latest upload.
timelocalSeconds since the unit last restarted.
latitude, longitude, altitude, speedPosition. Units set to "randomise" by their owner show slightly shifted coordinates to everyone except the owner.
city, countryBase city and 2-letter country code.
placement0 indoor, 1 outdoor.
status1 online, null offline.
mobile1 for mobile units.
versionsw, versionhwFirmware and hardware version.
detector, factorGeiger tube and its conversion factor from CPM to dose rate (µSv/h).
aqiEuropean Air Quality Index, 1 to 6: Good, Fair, Moderate, Poor, Very poor, Extremely poor (EEA bands revised in 2024), computed from PM2.5 and PM10.
note, picture, ownerOwner's note, picture URL, owner user ID.
param_XX, last_XX, avg_XXName and unit, latest value and moving average of sensor XX.
Sensor keys
Each unit reports the sensors of its model. GET /devices/{id} lists them.
GroupKeyMeaningUnit
Air qualitypm1, pm25, pm10PM1.0, PM2.5, PM10µg/m³
pm03no … pm10noParticle counts (0.3 to 10 µm)no/0.1L
co2Carbon dioxideppm
ch2oFormaldehydeppb
o3, no2Ozone, nitrogen dioxideppb
coCarbon monoxideppm
vocVolatile organic compounds (sensor resistance, index or µg/m³, depending on model)Ohm / Index / µg/m³
vocaqiVOC air quality indexAQI
gas1 … gas4Configurable electrochemical cells (name given in param_gasN)ppm (O2: % vol)
Radiationcpm, cpm2Geiger counter counts per minute. Dose rate in µSv/h = cpm × factorcpm
radonRadon concentrationBq/m³
Climate and weathertemperature, humidity, pressureAir temperature, relative humidity, barometric pressure (second sensor: suffix 2)°C, % RH, Pa
windspeed, windgustWind speed and gustm/s
windforceWind forceBeaufort
winddirectionWind direction°
rain, rainrateRain accumulation and intensitymm, mm/h
irradianceSolar irradianceW/m²
illuminanceIlluminancelux
uvUVmW/cm²
Noisenoise, noisemaxSound level and maximum (second microphone: noise2, noise2max)dB
Waterwtemperature, turbidity, do, orp, ec, phWater temperature, turbidity, dissolved oxygen, redox potential, conductivity, pH°C, NTU, µg/L, mV, ms/cm, pH
DevicesignalRadio signal strengthdBm
battery, voltage, dutyBattery voltage, Geiger tube voltage and duty cycleV, V, ‰
speed, altitude, satsMobile units: speed, altitude, GPS satelliteskm/h, m, no
Fair use: the uRADMonitor Shield
Your access tier in the API Terms sets how many calls your application may make. Independently, the Shield protects the network against abuse: it counts every call per IP address and refuses calls above these limits until the hour or the day resets.
Downloads / hourDownloads / dayUploads / hourUploads / day
1,0005,00010,000100,000
Calls without credentials have lower limits. If you need more for a research or public project, contact us.
API credits
Every upload from a unit you own adds one credit to your account. Credits accumulate and are shown in the API tab of the dashboard. They are not consumed by API calls at this time.
Embed live data
Every city and sensor page has a free embed code: a small live card plus a text link. It refreshes on its own and works on any website, including school and municipality sites.
License and citation
Values published on this website are available under Creative Commons Attribution 4.0 (CC BY 4.0). API access is governed by the General Terms and the API Terms, and is not covered by CC BY 4.0. When you publish results, cite: uRADMonitor environmental monitoring network, Magnasci SRL, https://www.uradmonitor.com.
API and data updates
Monthly summary and network news. One email a month, unsubscribe anytime.
Readings are indicative and not a substitute for official regulatory monitoring.
