I added support for uRADMonitor sensors to my AKWeather plugin for HomeSeer Automation.
Currently I implemented Server (Cloud) API, but since automation community always prefers using Local access (without Internet) – I will also add Local support.
Configuring the uRADMonitor provider is pretty straight forward – once the new Location is created in AKWeather plugin, all you need to do is select Uradmonitor provider from the list of providers and enter your API key.
When you click Save button – the plugin will obtain a list of available sensors, then you can either select the desired sensor from the list, or enter sensor ID manually. And Save again.
More information here in HomeSeer forum: uRADMonitor Air Quality Sensors
Alex, thank you for the excellent white up, and the development Homeseer plugin AKWeather. I use this my A3 model and works extremely well in integrate the data in the my HomeSeer system.
