Viewing 15 posts - 16 through 30 (of 87 total)
  • in reply to: Disable or extend time of Watchdog. #29301
    Hi Brian,
    It would help to know which model you are talking about…
    in reply to: CPM not available on website #29290
    The OP’s unit shows radiation level 0 all the time:
    https://uradmonitor.com/tools/dashboard-04/?open=13000214
    That’s not normal, since there is proper high voltage.
    in reply to: Lost WiFi password #29129
    A3 modules do have a USB port! It is even shown on its datasheet, page 1:
    A3 datasheet
    in reply to: Lost WiFi password #29123
    Hi Richard,
    In addition to what Evan wrote, there is a documentation about that:
    USB Serial Commands Manual
    You do find that stuff on the uRADMonitor product pages.
    EDIT: Link corrected
    in reply to: Firmware and changelog availability (for A3 HW:108) #29113
    Usually, firmwares update for units are personal. To get one, you’ll need to contact Radu stating your unit model and number, and hardware and firmware versions. He will compile a new firmware for you (if one is available) and sent it your way.
    I’ve done that for my Smoggie to get rid of the hotspot Wifi.
    in reply to: What is "WDT"? And other values #29096
    Hi Alex,
    CPM means “counts per minute” and corresponds to geiger tube discharges per minute.
    The units are pretty self-explanatory…if you still have questions, feel free to ask them here.
    HTH,
    in reply to: ozone 121 #29074
    Hi Ken,
    Yes, bad power supplies are responsible for most sensor failures. The sensors are indeed of good quality, the wall warts supplied are super cheap.
    Do you have access to an oscilloscope to check your power supply?
    What levels of ozone does your unit show when you used batteries?
    A dose of 30 to 50 ppb is already considered to be harmful to humans.
    WHO 2021 global air quality guidelines
    Ozone is nothing to do with pollution like nitrogen or carbon oxides.
    Concentration can be high on warm and sunny days.
    in reply to: ozone 121 #29031
    Hi Ken, can you try a different power supply?
    in reply to: Missing order confirmation SmoggiePM #29023
    Hi Jasper,
    You may want to contact user “Radu” directly about that.
    HTH,
    in reply to: Issue with map in dashboard #28950
    You’re welcome! Great you got your unit going!
    Have a nice day,
    in reply to: Issue with map in dashboard #28948
    I would say, your sensor is shown exactly where you have entered it. You can check on the map, zoom in, on the top right you see the coordinates where the mouse pointer is.
    Wild guess: you have the wrong coordinates.
    From your IP address, it seems you are located in the south of France. Could it be your position is 44.23N 5.32E (instead of 42.23N)?
    in reply to: Issue with map in dashboard #28946
    Which Sensor ID is it please?
    in reply to: A3: CO2 not adjusting for temp ? #28936
    Hi Radu,
    May I ask which dual-beam CO2 sensor you are using?
    I’m just thinking about upgrading my sensor as well…
    Thx,
    in reply to: formatos fecha y hora #28929
    Hola Esteban,
    The time is shown as “epoch”. It is the elapsed time in seconds since January 1st 1970 UTC time.
    There are converters to find everywhere, like epochconverter.com
    You can use a formula to convert epochs to Excel-Dates.
    HTH,
    in reply to: A3: CO2 not adjusting for temp ? #28890
    Hi Quincy,
    No need to be rude here, dude. I am /not/ the manufacturer, I’m just a customer like you are. I just wanted to point out how this system works.
    If you are not happy with its performance, talk to Radu.
    Cheers and EOD for me,
