- This topic has 9 replies, 3 voices, and was last updated 5 years, 3 months ago by
catalinberta.
November 2, 2020 at 6:20 pm #28550
catalinberta
ParticipantHey, noob here 🙂
I just got the Smoggie-CO2 id 17000014,. Thank you! Looking forward to putting it into action.
Though I have a problem, the SSID it shows is wrong as per documentation it should be uRADMontor-14, yet I find uRADMonitor-F2
The key doesn’t work 17000014, and I have also tried 170000F2 (to match the SSID I find) – neither work.I tried connecting via USB with CoolTerm on Mac (all drivers installed), yet a connection cannot be established.
It’s strange, as I do see this SSID appearing (and disappears periodically) – the sensor does light up, having a stable green led on.
Any help is highly appreciated, thanks!
November 3, 2020 at 10:02 am #28551catalinberta
ParticipantTo add on this, also tried on a win laptop and couldn’t establish any connection via CoolTerm (and other serial port means), using the baud rate 9600
November 3, 2020 at 5:28 pm #28553jank
ParticipantNot sure about the SSID name, but I found there was an issue with the provided DC power supply which caused a similar SSID up\down (once I turned the beeper on, it seemed the unit was actually rebooting). I have a different unit (A3) I’m just starting with – switching to one of my own power supplies (I borrowed from another device at home).
November 4, 2020 at 8:10 am #28556catalinberta
ParticipantThanks for the input jank. The provided power supply seems to be working and the Smoggie behaves the same even if I turn it on via USB.
November 4, 2020 at 11:27 am #28558uRADMonitor
Keymasterhi Catalin, seems something went wrong when provisioning your unit with the custom firmware . I will get back to you with the correct firmware on email. It’s very easy to program it, here are 2 tutorials:
November 4, 2020 at 4:34 pm #28563catalinberta
ParticipantThanks Radu, managed and I installed the new firmware, all good!
P.S. The reason why I wasn’t able to make an USB connection was because the provided cable either has the data layer broken or doesn’t have one for data transfer. I changed the cable and then I saw the Smoggie in Device Manager and I was able to update the firmware.
Data looking good so far. Looking forward to notifications
Keep up the awesome work!
April 13, 2021 at 6:38 am #28790uRADMonitor
Keymasterhi Catalin, some people seem to have trouble running the firmware update. Should you have the time, please consider writing a short tutorial on the blog to explain the steps you did . I can also send you the latest firmware.
April 14, 2021 at 12:01 pm #28798catalinberta
ParticipantHey Radu,
Sure, happy to do it.
I don’t remember how I did it and what I used, but I can install the latest firmware again and I can write all the steps down in a post this time.Could you please send me the latest firmware for Smoggie CO2?
April 14, 2021 at 6:22 pm #28800uRADMonitor
KeymasterGreat! Mail sent.
April 19, 2021 at 1:55 pm #28829catalinberta
ParticipantFYI The article is here https://www.uradmonitor.com/another-smoggie-firmware-guide-macos/
