- This topic has 3 replies, 2 voices, and was last updated 5 months, 3 weeks ago by .
I just noticed my unit (Model A) stopped reporting to the network about a month ago.
Currently running on a bench lab supply to rule out power supply issues (as that seems to be a common issue for others in the forum).
When checking its IP, it does produce output (see example below), but when the wdt counter reaches 240, the unit reboots.
I have checked that I can at least reach the stated server IP using traceroute, but not knowing what to look for in the communication I haven’t yet run Wireshark.
Is there anything I can do to troubleshoot further?
Sample output:
uRADMonitor 110000BC
type:1 hw:108 sw:126 SBM20
radiation:12CPM
temperature:23.75C
voltage:378V
duty:19%
frequency:15.50kHz
uptime:23s wdt:22s/240s
ip:192.168.13.37
server:66.228.41.43
interval:60 http:0 0/0
JSON [345]
Unit seems ok , but traffic to the server is blocked.
Do you ever get anything else than http:0 0/0 ? This means HTTP post return code (must be 200 to reset Watchdog), and x/y is number of successful packets (that got 200) / total packets attempted.
Check the router security , it must be blocking the sensor’s traffic.
You’re right, of course. Something was blocking the traffic.
Neither my ISP or my firewall were configured to do any blocking, but a reboot of both firewall and router seems to have solved it.
Thanks!
Interesting . The traffic itself is a simple HTTP Post to send the data, not unlike a browser opening a webpage. Good that the problem is gone!
