- This topic has 7 replies, 3 voices, and was last updated 6 years, 10 months ago by .
Are there alternative End Points for URADMonitors for transmitting the weather, radiation data?
I want to have MY DATA available on my multiple devices – Android smartphones, tablets, IFTTT, Zapier other IOTs.
Now data seems to be locked in and has to be pulled by 3rd parties via API only.
I couldn’t find a simple user-friendly solution for my needs (developer options do exist).
Thanks for reply.
It’s good to know it is possible to change end point. I do NOT want to run my firmware – I just want to send data to different location/IP.
Also see: https://www.uradmonitor.com/direct-data-access/ . It covers your question too.
@Wolferl,
1. Could you provide more details on how to duplicate data streams to different endpoints?
2. Do I understand it right that data format/structure can also be changed? If so – how?
@uradmonitor,
Your article linked above is cool, but not very clear on Method3 to what actual commands need yo be sent via USB to change endpoint.
Thanks.
You do realise that suggestion to change/recompile firmware fot a typical user lowers your customer base by A LOT.
I want to SIMPLY change where I send my data… sadly there seems no easy way to do that.
Great hardware limited by software.
Hello Paktas, let me assure you that there are at least several solutions to your need. First, what hardware are you using? Is it a KIT1? Is it a USB-capable device like the A3 , the SMOGGIE or the INDUSTRIAL?
The API is there so you can poll on multiple devices, Android smartphones, Tablets , all in your list – why doesn’t this work for you? This is currently used by most of the users and they are doing very cool stuff with it.
