- This topic has 2 replies, 2 voices, and was last updated 8 years, 9 months ago by .
Hi everyone,
I’m using nagios/check_mk to query the API on the sensor data for my device. I have an A3 model. Did anything change recently because, according to the API, it now has PM1 and PM10 sensors?
If I query the API I get the following list of sensors, but I thought the A3 model only has a PM2.5 sensor, is it a bug in the API/database?
URL: http://data.uradmonitor.com/api/v1/devices/82000095
Data:
“temperature”: “Temperature”,
“pressure”: “Pressure”,
“humidity”: “Humidity”,
“voc”: “VOC”,
“co2”: “Carbon Dioxide”,
“ch2o”: “Formaldehyde”,
“pm1”: “PM1.0”,
“pm25”: “PM2.5”,
“pm10”: “PM10”,
“noise”: “Noise”,
“cpm”: “Radiation”,
“voltage”: “Voltage”,
“duty”: “Duty cycle”,
“all”: “All”
The API also supplies values for those sensors, but they are not available in the Dashboard, only via the Data download page (https://www.uradmonitor.com/dashboard/#data)
Data:
“time”: 1515275599,
“latitude”: 48.7476,
“longitude”: 8.9592,
“altitude”: 429,
“temperature”: 8.68,
“pressure”: 96179,
“humidity”: 64.33,
“voc”: 201900,
“co2”: 513,
“ch2o”: 0.02,
“pm1”: 11.8413,
“pm25”: 9,
“pm10”: 7.9641,
“noise”: 34,
“cpm”: 22,
“voltage”: 382,
“duty”: 195
Kind regards
Matthias
The PM2.5 data is originally generated by the A3, which is then used to extrapolate the PM1.0 / PM10.0 via a linear model, which you probably saw already due to the common chart shapes. There’s a lot of literature covering this topic, and more transformation models. So we might see changes to these calculations in the future.
Thanks for the explanation.
