Home Forum Support System beep
Viewing 9 posts - 31 through 39 (of 39 total)
  • #6573
    andreas
    Hi Radu
    We‘re back at the beeping again with unit 82000134. How can it be, that this setting is off again? Can it be set to mute via website meanwhile?
    Cheers
    Andreas
    #6574
    You mean it is beeping again? That would be strange. I just issued another “mute” command from the server. Please check on next reconnect. Thanks
    #6615
    andreas
    Thank you, it seems to be silent again.
    #6620
    mmx
    Hi Radu,
    can you please also disable the beep for my device 82000095
    Thanks
    Matthias
    #6626
    Done. please confirm.
    #6628
    mmx
    Hi Radu,
    after power on there is immediately one beep, then the device is silent, is that as expected?
    Matthias
    #6687
    Manust
    Hi Radu,
    Please mute 8200007F it’s been beeping (one beep each time) a lot for the last 3 days, almost every hour.
    Thanks
    #6689
    8200007F muted.
    #6691
    Manust
    it was indeed, thank you.
    I found it to be a Mozilla-IOT plugin that was generating a lot of ARP boradcast requests on the network, saturating the A3 Ethernet stack until it crashed and looped.
