Home Forum Support System beep
Viewing 15 posts - 1 through 15 (of 38 total)
  • #5780
    It can be done via the server side. There will be an option on the dashboard for that so you can configure it yourself, but it is not yet implemented. So I can do it manually for the time being.
    What ID do you want to be muted?
    #5781
    Urs Wirthmueller
    It would be both units 82000075 and 82000071
    #5782
    Hi Urs, I set the command on the server, it should be applied the first time the units communicate with the server. Please confirm once they do and you see this in place.
    #5784
    Urs Wirthmueller
    It worked – thank you for your support!
    #5786
    My pleasure, glad all is ok, thanks for the update!
    #5919
    Urs Wirthmueller
    The new industrial unit is up and running – perfect.
    May I also ask you to switch off the system beep for this unit, too (14000013).
    Thank you
    #5980
    The 14000013 should be muted now. Please confirm.
    Thanks
    #6009
    daniweb
    can you please also mute for my A3 ?
    820000FA
    Thanks
    #6072
    Command to mute 820000FA was added to the server. It will apply on first A3 communication. Please confirm when it’s done.
    #6212
    andreas
    Hey Radu
    Please mute mine as well: 82000134
    Thank you very much.
    Regards,
    Andreas
    #6218
    andreas
    Are there any known issues with the urad network today? A whole lot of units are offline and my A3 is resetting every couple of minutes with the annoying beeps. I had to shut the unit off, otherwise my family will not be able to sleep tonight.
    Andreas
    #6228
    Hello @andreas, beep command has been issued for your ID, it will get muted the first time it connects. There were some changes being made on the server side, this is why all the units rebooted. Now we’re on a bigger, faster server. Had to do that to cope with the increased traffic.
    @wolferl
    yes , you are right. Hopefully we’ll see that soon.
    #6268
    a01
    Hi Radu,
    Please mute 82000127.
    It’s been beeping a lot late at night yesterday and today — and it’s very loud!
    Thanks
    #6270
    WeakNerve
    Please mute my A3 as well! 🙂 Thanks! 8200010A
    #6276
    Hi @a01 and @weaknerve , both units set to go to mute. Please confirm.
