- This topic has 3 replies, 2 voices, and was last updated 6 years ago by .
Hi, bought the uRADMonitor A3 (Wifi model) and just got it today. Was setting it up, but could not see the SSID in the pattern “uRADMonitor-**”
Well I actually saw it for a split second, but it disappeared right after and i have not been able to see it since. Is there any way to reset the A3 or is unplug/plug the only thing I can do? I actually have been doing the unplug + plug for about 30 min now. Still can’t find the SSID.
Would appreciate any help!
Had a similar issue.
Have you tried to use the USB power supply?
Yea I’m trying the USB method found here now – https://www.uradmonitor.com/wordpress/wp-content/uploads/2020/08/uRADMonitor_WIFI_CONFIG_comp.pdf
But not seeing any output in the CoolTerm output
Occasionally something gets stuck I think. What I did (worked after a couple times):
1.Unplug USB, wait a few seconds
2.Plug USB in
3.Attempt to connect CoolTerm. (if no output on connection, go to step 1)
