Home › Forum › Support › Radiation spikes?
  • #2839
    Cottees
    Has anyone seen this before? On the uRADMonitor website, it looks all ok.
    uRADScreenshot
    But on the data I have got from my uRADMonitor and graphed locally, it shows a couple spikes in radiation.
    cactirad
    The other data like the temperature looks to be ok.
    uradtemp
    I am reading the JSON file with PHP and extracting the data from that so Cacti can read and graph it. And that does that once every 5 minutes.
    Edit: The lack of data at the end of the graph is I was moving things around and knocked an ethernet cable.
    • This topic was modified 10 years, 8 months ago by Cottees.
    #2841
    Currently the server holds only 1 in 10 readings, to lower the load. This will be soon changed to an average of the 10 values instead.
    What you got there is clearly a radiation spike. How often did you notice these?
    #2842
    Cottees
    This is the total time I have had the uRADMonitor being logged locally. So I have only noticed it twice so far, both within a 24 hour period.
