- This topic has 7 replies, 2 voices, and was last updated 8 years, 8 months ago by
Robert.
January 8, 2018 at 9:30 am #5462
Robert
ParticipantI have just installed my uRad A3 last week
After some confusion about the VOC sensor output was cleared up, another question remains: I’m noticing sudden jumps of values for some of the sensors. Specifically the temperature sensor and the CO2 sensor seem to suffer from this.
Has anybody else noticed similar flukes?
January 9, 2018 at 9:36 am #5467Robert
ParticipantThe erroneous values seem to be inversions of the actual values. When mirroring these erroneous values around the X-axis, the result seems to make sense. This sign-flipping seems to occur at temperatures just around +1°C.
January 9, 2018 at 2:36 pm #5473uRADMonitor
KeymasterThanks to your findings, I was able to identify a bug in the temperature encoding scheme:
uint16_t double2int(double val) { int8_t sintp = (int8_t)val; //signed integer part int8_t sdecp = (val - sintp ) * 100; //signed decimal part uint8_t udecp = sdecp>0?sdecp:-1*sdecp; //removed decimal sign uint8_t uintp = sintp + 127; //convert to unsigned uint16_t res = (udecp << 8) | (uint16_t)uintp; //pack it together return res; }The sign is lost when the integer part is 0, exactly all values between 0 and -1. The fix is added to the firmware as we speak, unless it can be solved on the server side.
For CO2, let’s continue herE: https://www.uradmonitor.com/topic/co2-sensor/
January 9, 2018 at 3:22 pm #5475Robert
ParticipantThank you for sharing. I’ve put the code in a little test program:
uint16_t double2int(double val) { int8_t sintp = (int8_t)val; /* signed integer part */ int8_t sdecp = (val - sintp) * 100; /* signed decimal part */ uint8_t udecp = (sdecp > 0) ? sdecp : -sdecp; /* removed decimal sign */ uint8_t uintp = sintp + 127; /* convert to unsigned */ uint16_t res = (udecp << 8) | (uint16_t)uintp; /* pack it together */ return res; } int main(int argc, char *argv[]) { double value; for (value = -2.0; value < 2.01; value += 0.1) { uint16_t converted = double2int(value); printf("value = %f, converted = %u\n", value, converted); } }And I’m getting the following result:
value = -2.000000, converted = 125 value = -1.900000, converted = 22910 value = -1.800000, converted = 20350 value = -1.700000, converted = 17790 value = -1.600000, converted = 15230 value = -1.500000, converted = 12670 value = -1.400000, converted = 10110 value = -1.300000, converted = 7550 value = -1.200000, converted = 4990 value = -1.100000, converted = 2430 value = -1.000000, converted = 25471 value = -0.900000, converted = 22911 value = -0.800000, converted = 20351 value = -0.700000, converted = 17791 value = -0.600000, converted = 15231 value = -0.500000, converted = 12671 value = -0.400000, converted = 10111 value = -0.300000, converted = 7551 value = -0.200000, converted = 4991 value = -0.100000, converted = 2431 value = 0.000000, converted = 127 value = 0.100000, converted = 2687 value = 0.200000, converted = 5247 value = 0.300000, converted = 7807 value = 0.400000, converted = 10367 value = 0.500000, converted = 12927 value = 0.600000, converted = 15487 value = 0.700000, converted = 18047 value = 0.800000, converted = 20607 value = 0.900000, converted = 23167 value = 1.000000, converted = 128 value = 1.100000, converted = 2688 value = 1.200000, converted = 5248 value = 1.300000, converted = 7808 value = 1.400000, converted = 10368 value = 1.500000, converted = 12928 value = 1.600000, converted = 15488 value = 1.700000, converted = 18048 value = 1.800000, converted = 20608 value = 1.900000, converted = 23168 value = 2.000000, converted = 129Though I’m not really sure what I’m looking at. Can you tell me what goes in and what’s supposed to come out? Is the output supposed to be a fixed-point value?
January 9, 2018 at 5:59 pm #5476uRADMonitor
KeymasterI’ve provided more details on email, please check it. But for the continuity of the topic, the bug becomes apparent when you decode the “converted” values. Please add the decoding function:
double int2double(uint16_t val) { int8_t d = (val >> 8) & 0xFF; int8_t i = (val & 0xFF) - 127; if (i < 0) d *= -1; return i + d / 100.0; }The if (i < 0) d *= -1; won't trigger when i is 0. The problem with this algorithm is that we have no way of knowing the sign, when the integer byte is 0. Exactly the bug you have spotted. Try this code to the "converted" values, and check the more details I sent on your email. I tried to see if this is fixable on the server side, but apparently information is lost on the conversion. A new encoding scheme has been added to the firmware. We will need to install this new firmware on all affected units.
January 14, 2018 at 9:39 pm #5484Robert
ParticipantAs suggested per email, but to keep this top compleet: Why not using standard 16-bit signed integers?
Conversions back and forth with a little test program would look like this:
#include <stdio.h> #include <stdint.h> #define FIXED_POINT_FACTOR 100.0; int16_t double2fixed(double val) { val *= FIXED_POINT_FACTOR; if (val > INT16_MAX) return INT16_MAX; if (val < INT16_MIN) return INT16_MIN; return val; } double fixed2double(int16_t val) { return val / FIXED_POINT_FACTOR; } int main(int argc, char *argv[]) { double value; // for (value = -328.70; value < -326.01; value += 0.1) /* Test bottom edge case */ // for (value = 326.00; value < 329.01; value += 0.1) /* Test top edge case */ for (value = -2.0; value < 2.01; value += 0.1) /* Test around zero */ { int16_t converted = double2fixed(value); double back = fixed2double(converted); printf("value = %f, converted = %d, back = %f\n", value, converted, back); } }January 15, 2018 at 10:11 am #5485uRADMonitor
KeymasterYes, that would work too. Something similar was added in firmware v130 as a fix:
// an uint16_t stores 16 bits, we use first bit for sign, and following 15 bits for number (0..32767) // result is divided by 100 for a real with 2 decimals, max is 327.00 uint16_t di(double val) { uint16_t res = 0; uint16_t mask = 1<<15; if (val > 327 || val < -327) return res; if (val < 0) { val *= -1000; res = val / 10; // fix double approximation issue res |= mask; } else { val *= 1000; res = val / 10; // fix double approximation issue } return res; }and
// an uint16_t stores 16 bits, we use first bit for sign, and following 15 bits for number (0..32767) // result is divided by 100 for a real with 2 decimals, max is 327.00 double id(uint16_t val) { double res = 0; uint16_t mask = 1<<15; // check negative number if (val & mask) { val &= ~mask; // remove sign bit res = val; res = -res; } else { res = val; } res /= 100.0; // restore the 2 decimals return res; }It’s pretty much the same thing.
January 15, 2018 at 10:56 am #5486Robert
ParticipantYes, that would work too.
And it’s standard. And it’s a lot easier to read.
Yes and no, but mostly no.
The intermediate 16-bit value function di() produces uses a proprietary bit layout. Besides being non-standard and harder to read code, another consequence is that standard arithmetics – like adding, subtracting, multiplying and dividing – do not work on negative numbers. Perhaps there’s still a good reason to use this proprietary format, but it must be a really good one to justify the disadvantages.Standard negative numbers use two’s complement for negative counter parts of positive integers. This is necessary to keep standard arithmetics intact and hence 0 – 1 = -1. With your proprietary format, you have two zeroes: +0 and -0. And standard arithmetics are broken: +0 – 1 = -32767 and -0 – 1 = 32767
Double: | Standard conversion (binary) | Proprietary conversion (binary)| Standard reverse | Proprietary reverse -------------+-----------------------------------------+--------------------------------+---------------------+--------------------- value = -2.00, double2fixed = -200 (0b1111111100111000), di = 32968 (0b1000000011001000), fixed2double = -2.00, id = -2.00 value = -1.90, double2fixed = -190 (0b1111111101000010), di = 32958 (0b1000000010111110), fixed2double = -1.90, id = -1.90 value = -1.80, double2fixed = -179 (0b1111111101001101), di = 32947 (0b1000000010110011), fixed2double = -1.79, id = -1.79 value = -1.70, double2fixed = -169 (0b1111111101010111), di = 32937 (0b1000000010101001), fixed2double = -1.69, id = -1.69 value = -1.60, double2fixed = -159 (0b1111111101100001), di = 32927 (0b1000000010011111), fixed2double = -1.59, id = -1.59 value = -1.50, double2fixed = -149 (0b1111111101101011), di = 32917 (0b1000000010010101), fixed2double = -1.49, id = -1.49 value = -1.40, double2fixed = -139 (0b1111111101110101), di = 32907 (0b1000000010001011), fixed2double = -1.39, id = -1.39 value = -1.30, double2fixed = -129 (0b1111111101111111), di = 32897 (0b1000000010000001), fixed2double = -1.29, id = -1.29 value = -1.20, double2fixed = -119 (0b1111111110001001), di = 32887 (0b1000000001110111), fixed2double = -1.19, id = -1.19 value = -1.10, double2fixed = -109 (0b1111111110010011), di = 32877 (0b1000000001101101), fixed2double = -1.09, id = -1.09 value = -1.00, double2fixed = -99 (0b1111111110011101), di = 32867 (0b1000000001100011), fixed2double = -0.99, id = -0.99 value = -0.90, double2fixed = -89 (0b1111111110100111), di = 32857 (0b1000000001011001), fixed2double = -0.89, id = -0.89 value = -0.80, double2fixed = -79 (0b1111111110110001), di = 32847 (0b1000000001001111), fixed2double = -0.79, id = -0.79 value = -0.70, double2fixed = -69 (0b1111111110111011), di = 32837 (0b1000000001000101), fixed2double = -0.69, id = -0.69 value = -0.60, double2fixed = -59 (0b1111111111000101), di = 32827 (0b1000000000111011), fixed2double = -0.59, id = -0.59 value = -0.50, double2fixed = -49 (0b1111111111001111), di = 32817 (0b1000000000110001), fixed2double = -0.49, id = -0.49 value = -0.40, double2fixed = -39 (0b1111111111011001), di = 32807 (0b1000000000100111), fixed2double = -0.39, id = -0.39 value = -0.30, double2fixed = -29 (0b1111111111100011), di = 32797 (0b1000000000011101), fixed2double = -0.29, id = -0.29 value = -0.20, double2fixed = -19 (0b1111111111101101), di = 32787 (0b1000000000010011), fixed2double = -0.19, id = -0.19 value = -0.10, double2fixed = -9 (0b1111111111110111), di = 32777 (0b1000000000001001), fixed2double = -0.09, id = -0.09 value = 0.00, double2fixed = 0 (0b0000000000000000), di = 0 (0b0000000000000000), fixed2double = 0.00, id = 0.00 value = 0.10, double2fixed = 10 (0b0000000000001010), di = 10 (0b0000000000001010), fixed2double = 0.10, id = 0.10 value = 0.20, double2fixed = 20 (0b0000000000010100), di = 20 (0b0000000000010100), fixed2double = 0.20, id = 0.20 value = 0.30, double2fixed = 30 (0b0000000000011110), di = 30 (0b0000000000011110), fixed2double = 0.30, id = 0.30 value = 0.40, double2fixed = 40 (0b0000000000101000), di = 40 (0b0000000000101000), fixed2double = 0.40, id = 0.40 value = 0.50, double2fixed = 50 (0b0000000000110010), di = 50 (0b0000000000110010), fixed2double = 0.50, id = 0.50 value = 0.60, double2fixed = 60 (0b0000000000111100), di = 60 (0b0000000000111100), fixed2double = 0.60, id = 0.60 value = 0.70, double2fixed = 70 (0b0000000001000110), di = 70 (0b0000000001000110), fixed2double = 0.70, id = 0.70 value = 0.80, double2fixed = 80 (0b0000000001010000), di = 80 (0b0000000001010000), fixed2double = 0.80, id = 0.80 value = 0.90, double2fixed = 90 (0b0000000001011010), di = 90 (0b0000000001011010), fixed2double = 0.90, id = 0.90 value = 1.00, double2fixed = 100 (0b0000000001100100), di = 100 (0b0000000001100100), fixed2double = 1.00, id = 1.00 value = 1.10, double2fixed = 110 (0b0000000001101110), di = 110 (0b0000000001101110), fixed2double = 1.10, id = 1.10 value = 1.20, double2fixed = 120 (0b0000000001111000), di = 120 (0b0000000001111000), fixed2double = 1.20, id = 1.20 value = 1.30, double2fixed = 130 (0b0000000010000010), di = 130 (0b0000000010000010), fixed2double = 1.30, id = 1.30 value = 1.40, double2fixed = 140 (0b0000000010001100), di = 140 (0b0000000010001100), fixed2double = 1.40, id = 1.40 value = 1.50, double2fixed = 150 (0b0000000010010110), di = 150 (0b0000000010010110), fixed2double = 1.50, id = 1.50 value = 1.60, double2fixed = 160 (0b0000000010100000), di = 160 (0b0000000010100000), fixed2double = 1.60, id = 1.60 value = 1.70, double2fixed = 170 (0b0000000010101010), di = 170 (0b0000000010101010), fixed2double = 1.70, id = 1.70 value = 1.80, double2fixed = 180 (0b0000000010110100), di = 180 (0b0000000010110100), fixed2double = 1.80, id = 1.80 value = 1.90, double2fixed = 190 (0b0000000010111110), di = 190 (0b0000000010111110), fixed2double = 1.90, id = 1.90 value = 2.00, double2fixed = 200 (0b0000000011001000), di = 200 (0b0000000011001000), fixed2double = 2.00, id = 2.00 -
