Home Forum Software Disable unit's WiFi network; Web interface tweaks
  • #6032
    a01
    Hi Wolferl,
    Thanks for answering my question about the country setting. The link I gave was just an example, but my device is an A3 (hw version 105). I’ve updated the city and latitude/longitude/altitude, so that should be good enough for now.
    #6083
    hi @slifox, the flag is changed now: https://www.uradmonitor.com/tools/dashboard-04/?open=82000127
    I’ll be adding the country as an editable option in the dashboard soon.
    The firmware supports disabling the local hotspot after a predefined number of seconds. It will literally be shutdown. But there is no parameter for this, the firmware needs to be recompiled. If you are willing to update the firmware on your unit, I can send you the one that does this.
