Home › Forum › Support › Changing the coordinates
Viewing 15 posts - 1 through 15 (of 28 total)
  • #3113
    You can have the coordinates of your units changed by posting a requirement for that, either here or by email, but please specify unit ID, coordinates in decimal format (what you get by right clicking on Google maps for instance), city name and altitude if available.
    In the close future, there will be a public interface where you’ll be able to manage your stations directly, but until we get there we’ll do it manually.
    Please use the dashboard to set the location on map: https://www.uradmonitor.com/dashboard/
    #3485
    BB
    I would if I could 🙂 – the IP on my unit (11000045) is different to my desktop so I can’t “claim” it via the dashboard. Could you please assign it to my account (you should see they’re in the same /24 subnet).
    It now shows with a location in London with many others so you can’t click on it (I had to dig out the ID to get the graph up). Could this be fixed to show multiple graphs when you’re at max zoom on the graph and there are still multiple units at the same location?
    Chris.
    #3486
    Hi Chris, yes to both questions. Please check the dashboard now. Thanks!
    #3827
    Keld Norman
    My account says ” There are no units attached to your account. ” how do I attach my unit to my account ?
    ( https://www.uradmonitor.com/?open=1100000A and account name: keld.norman )
    best regards
    Keld Norman
    #3828
    The unit will appear automatically listed in the Dashboard, IF you are in the same LAN as your unit. We’re using IP address to do the matching.
    If this is not possible let me know, and I will change it manually.
    Thanks!
    #3831
    Keld Norman
    Hi Radhoo – I am at the same LAN. That would be the same external IP is shown for the https://www.uradmonitor.com connection that I do as the unit does when uploading data – but the unit is placed in another network segment then what i am in with my PC.
    Idem still do not see any unit in the view.
    Please add the unit to my account if possible. (1100000A and account name: keld.norman)
    Regards Keld Norman.
    #3857
    I went to the DB to do the changes manually, then I save the 1100000A is already assigned to your user id. Please click the Dashboard and post a screenshot with what you see there: https://www.uradmonitor.com/dashboard/
    Thanks!
    #3859
    Keld Norman
    Hi – It is there now – perfect! 🙂 🙂 and the coordinates can be change + the altitude – thanks
    Is the firmware 115 the newest? The unit is labeled A.3.4
    #3862
    Latest firmware is v123 . Here is what you need: https://www.uradmonitor.com/firmware-upgrade-guide/
    #4135
    SaltoUYStation
    Hello Radu and thanks again for the Model A. Got it hooked up, but map shows it’s in Shekou, China. Don’t see how in the dashboard I can change the coordinates. Sent my coordinates and unit id via email. It registers a lovely 10 on the map! Awesome.
    #4139
    SaltoUYStation
    Thanks for the quick fix, Radu! Now transmitting from Uruguay and on the map in South America.
    #4166
    Perfect! thanks for the update!
    #5401
    Bjorn Roesbeke
    Quick question: should the altitude be the true altitude above (or below!) sealevel [better be storing signed floats in DB] or above ground?
    If installed correctly, everyone’s unit should be 1m above ground therefore it can’t be anything else than difference in height to sealevel, right?
    #5436
    That is correct, and thanks for pointing out there is no description for this parameter. I need to fix that.
    I should be the altitude above sea level.
    #5726
    barnestom
    Any thoughts on why my A3 is showing a Polish flag, despite coordinates and city being correct in Portsmouth UK?
