- This topic has 16 replies, 3 voices, and was last updated 7 years ago by
uRADMonitor.
January 6, 2019 at 2:28 pm #6387
Ken Scott
ParticipantIt appears my device is having a fault.
It boots up and is responsive for maybe a minute then drops.
Power is on but communication stops.Starting continuous ping to 192.168.4.155 – Jan 06, 2019 09:27:22
Ping # IP Address RTT(ms) TTL Bytes Received
1 192.168.4.155 2 63 64
2 192.168.4.155 5 63 64
3 192.168.4.155 5 63 64
4 192.168.4.155 3 63 64
5 192.168.4.155 3 63 64
6 192.168.4.155 4 63 64
7 192.168.4.155 2 63 64
8 192.168.4.155 4 63 64
9 192.168.4.155 3 63 64
10 192.168.4.155 3 63 64
11 192.168.4.155 4 63 64
12 192.168.4.155 5 63 64
13 192.168.4.155 3 63 64
14 192.168.4.155 5 63 64
15 192.168.4.155 2 63 64
16 192.168.4.155 4 63 64
17 192.168.4.155 2 63 64
18 192.168.4.155 2 63 64
19 192.168.4.155 2 63 64
20 192.168.4.155 3 63 64
21 192.168.4.155 3 63 64
22 192.168.4.155 2 63 64
23 192.168.4.155 3 63 64
24 192.168.4.155 4 63 64
25 192.168.4.155 4 63 64
26 192.168.4.155 3 63 64
27 192.168.4.155 6 63 64
28 192.168.4.155 3 63 64
29 192.168.4.155 3 63 64
30 192.168.4.155 6 63 64
31 192.168.4.155 3 63 64
32 192.168.4.155 3 63 64
33 192.168.4.155 4 63 64
34 192.168.4.155 4 63 64
35 192.168.4.155 4 63 64
36 192.168.4.155 4 63 64
37 192.168.4.155 3 63 64
38 192.168.4.155 2 63 64
39 192.168.4.155 2 63 64
40 192.168.4.155 4 63 64
41 192.168.4.155 2 63 64
42 192.168.4.155 3 63 64
43 192.168.4.155 3 63 64
44 192.168.4.155 2 63 64
45 192.168.4.155 2 63 64
46 192.168.4.155 3 63 64
47 192.168.4.155 3 63 64
48 192.168.4.155 3 63 64
49 192.168.4.155 3 63 64
50 192.168.4.155 4 63 64
51 192.168.4.155 1117 63 64
52 TIMED OUT
53 TIMED OUT
54 TIMED OUT
55 TIMED OUT
56 TIMED OUT
57 TIMED OUT
58 TIMED OUT
59 TIMED OUT
Ping canceled
Ping Successful
51 of 59 packets returned successfully : 13.6% PACKET LOSS
Round Trip Time (in milliseconds) Maximum/ Minimum/Average: 1117/1117/25January 6, 2019 at 10:32 pm #6389uRADMonitor
KeymasterCan you open the unit’s IP in your browser to see what the internal webserver puts out? It is possible the high voltage inverter is failing to produce 380V, resulting in a reboot. Then it goes for DHCP lease again (~12sec) and so on.
January 6, 2019 at 10:44 pm #6390Ken Scott
ParticipantuRADMonitor 110000E7
type:1 hw:109 sw:115 SBM20radiation:0CPM
average:0.00CPM
temperature:28.50Cvoltage:149V (13%)
uptime:13s
wdt:13sip:192.168.4.155
server:45.79.179.145
http:0January 8, 2019 at 10:41 am #6406Ken Scott
Participanthow do I get it fixed?
January 19, 2019 at 5:18 pm #6415Ken Scott
ParticipantInspected unit and there is no sign of damage or moisture.
Tried a new power supply.
Runs fine for a few minutes then drops.How do we handle the repair?
January 20, 2019 at 3:59 pm #6417Ken Scott
ParticipantDo you have the schematics for it?
No I don’t. are they available?January 22, 2019 at 10:09 pm #6421Ken Scott
ParticipantIn every case when I power it up it functions correctly with proper voltage, however after a few minutes it then drops. Should I proceed with the test you outlined?
I do have a multimeter but am fairly unskilled at electronics.January 29, 2019 at 10:18 pm #6441uRADMonitor
KeymasterEasiest solution would be a firmware upgrade, to help the high voltage inverter that seems to be failing.
Here’s how to do it: https://www.uradmonitor.com/firmware-upgrade-guide/
Can you get the usbASP programmer and try this? If yes I’ll send you the new firmware hex file.
February 2, 2019 at 1:40 pm #6457Ken Scott
Participanti have ordered the usbASP
February 14, 2019 at 12:19 am #6458Ken Scott
Participantsent emails, messages and no response. Please email the firmware.
March 2, 2019 at 4:12 pm #6483March 6, 2019 at 8:35 am #6486uRADMonitor
KeymasterI also lowered the inverter’s frequency, do you hear any hissing sound?
