Home Forum Support [Solved] Unit won’t connect from 4G network
Viewing 15 posts - 1 through 15 (of 24 total)
  • #837
    Lars
    After 09.12.2014 my unit 11000016 won’t connect anymore.
    I don’t think it’s the same as in https://www.uradmonitor.com/topic/networking-issues/, because it worked before.
    I haven’t tried wireshark yet, but have tested it on several networks. Blinking lights, but no updates on web.
    • This topic was modified 11 years, 3 months ago by uRADMonitor.
    • This topic was modified 11 years, 3 months ago by Lars.
    #838
    Peter
    – look at the router, delete dhcp ip adress for uradmonitor. Than reconnect.
    – If you have a Fritzbox that make problems…
    – test at another router.
    Peter
    #847
    Lars
    Connected via laptop to check out the traffic. Wireshark says the urad is getting “400 Bad Request”.
    Request:
    416 706.134489 10.42.0.22 23.239.13.18 HTTP 228 [TCP Retransmission] GET http://data.uradmonitor.com/upload/0.1/upload.php?id=11000016&p=82&ts=60&inv=377&ind=453&s1t=27.00&cpm=30 HTTP/1.1 Continuation or non-HTTP traffic
    Response:
    456 886.170028 23.239.13.18 10.42.0.22 HTTP 520 HTTP/1.1 400 Bad Request (text/html)
    And nothing on map:
    Home
    Server side error?
    • This reply was modified 11 years, 3 months ago by Lars. Reason: screenshot
    #850
    Andromedan
    Yep, defintitely server side, look at the originiating IP address in Wireshark.
    Although code 400 is for bad client side data sent. Corrupted packets?
    #851
    Lars
    Yes, perhaps corrupted packets:
    1199 5505.750204 23.239.13.18 10.42.0.22 TCP 58 [TCP Previous segment lost] http > metaconsole [SYN, ACK] Seq=142071037 Ack=1 Win=29200 Len=0 MSS=1460
    Buy why? Bad soldering? Bad cable? Too low input voltage?
    I have tried two different TP cables.
    #852
    Andromedan
    Indeed very odd. Tried another PSU?
    #857
    vinz
    Member
    Hello,
    @Radhoo, could you comment this, maybee there were updates this time?
    Is it correct you have two IPs, for data. and main domain?
    @Lars
    , do you have a selfmade firewall which hacks packets out? 🙂
    Vinz
    #859
    I’m afraid there were no updates. So the change must have been local. Yes, currently there are several IP used. The one for data is correct: 23.239.13.18.
    Lars, just as a note, I don’t think this is physical, nevertheless if you are unable to find the problem, you can send the unit back anytime to get a replacement.
    #877
    Lars, I found the problem
    Your unit resolves the server DNS as it would be uradmonitor.com instead of data.uradmonitor.com
    The packets are hitting the wrong server.
    I will see what I can do at my end.
    • This reply was modified 11 years, 3 months ago by uRADMonitor.
    #878
    Here is a snapshot of the access log. Because the packets are not landing on data.uradmonitor.com, the server issues a HTTP 400.
    As the unit is unable to get a valid reply, it auto-resets after 5 minutes. See the ts parameter, which is the local time of the unit in seconds, it never goes over 240 (=4×60 seconds, on the fifth it resets).
    Two units are currently having this problem, 11000016 and 11000009 . I will find out why.
    #885
    Orellanine
    I think we need a support forum.
    #889
    Good idea. Support forum created and this topic moved.
    Regarding the problem, I have investigated things further. Must say this seems to be an elusive bug and I have wasted a few hours to track it already.
    Apparently the two units get to the server with their User Agent info stripped. Probably other parts of the packages are changed as well. Also the source IP is null. I don’t know what on their route changes their HTTP headers. Local tests didn’t show this issue, and it is impossible to consider a malfunction of any kind.
    I can only assume a firewall would be able to have this intrusive result.
    With the User Agent info removed and no source IP, the server denies the packages with a HTTP 400 Error code (Bad request).
    I will see what I can do about this.
    #891
    @Rick, the problem for 11000009:
    [Fri Dec 12 21:46:27 2014] [debug] protocol.c(792): [client 72.47.*.*] Request header field is missing ‘:’ separator: \x01\xff\xff\xff
    [Fri Dec 12 21:46:27 2014] [error] [client 72.47.*.*] request failed: error reading the headers
    @Lars
    , the problem for 11000016:
    [Fri Dec 12 21:44:42 2014] [debug] protocol.c(792): [client 178.255.*.*] Request header field is missing ‘:’ separator: /\xf3\x01\xff\xff\xff
    [Fri Dec 12 21:44:42 2014] [error] [client 178.255.*.*] request failed: error reading the headers
    #894
    Lars
    I’ve got a new modem/router now (unrelated), so I’ll see over the weekend if that helps.
    How ever, is there anything missing in the packets you see in https://www.uradmonitor.com/wordpress/wp-content/uploads/2014/12/Screen-Shot-2014-12-12-at-16.31.25-copy.jpg ? The requests look normal to me.
    #895
    It does look normal, but the header is missing. This results in the 400 Error code. The image shows a dash on each row. For other units there’s the user agent there.
    What’s strange is that a few days ago, 11000016 was working fine . Did anything change in the network setup?
    For Rick’s unit, 11000009 the problem was from the beginning.
    But both units worked perfectly here, while running the tests.
