Home Forum Support WiFi Issue with A3 82000074
  • #6512
    Adam
    Thanks Wolferl.
    I was able to get it back online, although it’s not an ideal setup. I had to add an old wireless access point to my network. I had disconnected the A3 while redoing some things in my shop and after reconnecting it would not connect (or stay connected long enough to test). The only thing I had changed was to update my network to use Unifi instead of the older Asus hardware. I installed an old mobile access point and voila it reconnected. Will the hardware support more modern wifi networks if I updated the firmware?
    How do I go about getting updated firmware?
    Thanks,
    Adam
    #6525
    Hi Adam,
    Like Wolferl very well said, you won’t be able to use WPA3 with relatively limited embedded hardware, but WPA/WPA2 will work just fine.
    What is your current wifi config?
    #6529
    Adam
    Radu,
    I currently have it set with WPA2 and BG operation and its working well. I believe my router had some newer technologies that weren’t compatible with some devices so I have a second access point just for these.
    Would a firmware update be beneficial or is it recommended to stay with the version I’m currently running? type:8 hw:103 sw:124 SI29BG
    thanks!
    Adam
    #6530
    Hi Adam, thanks for the clarifications. You can use your current firmware.
