- This topic has 14 replies, 6 voices, and was last updated 8 years, 8 months ago by
May 16, 2017 at 10:49 am #4415
JPRuehmann
ParticipantThe Homepage shows Voice as Chooseable Sensor but no Data.
Wy is the Option shown if there is no such Sensor in my Device?
Thanks,May 16, 2017 at 12:47 pm #4418SaltoUYStation
ModeratorHi Jan-Peter,
I have the Model A and it does not have the VOC (Volatile Organic Compound: https://en.wikipedia.org/wiki/Volatile_organic_compound) option, but other models do (shown in colorful circles on the map in screen shot below). My take is that while some of us do not have all the available sensors, the map choices reflect all of them so we can all see the data of those who do have multiple sensors in their units.
May 16, 2017 at 2:40 pm #4420JPRuehmann
ParticipantI can´t find a Model with Microphone therefore this data and option have no point.
Secondly I don´t think a Micro in this Devices is a good Idea at all.
There are enough spying Devices such as Google Echo, Handys with apps such as Siri or Alexa and so on around.
We don´t need to give the NSA more Data.May 16, 2017 at 3:54 pm #4421SaltoUYStation
ModeratorI need to clarify something – your original post you said you were concerned about the Noise option and I had forgotten there was a new “noise pollution” option, which is why I went on about the VOC. I thought maybe you meant the VOC, so, my apologies for my confusion. I’ve asked Radu in facebook about the sensor for the noise pollution monitor.
May 31, 2017 at 11:21 am #4475uRADMonitor
KeymasterHi Guys, sorry for the slow reply.
A new hardware revision of the A3 model (v105) comes with a noise pollution sensor. This cannot be used to record voice, as it is limited to just a few samples per minute (Voice goes in the kHz range, that means a few thousands of samples per second).
The noise pollution is a critical issue in cities, affecting life quality directly, this is why we need to address it as well.
as for the other questions:
“The Homepage shows Voice as Chooseable Sensor but no Data.”
The option is called “Noise”, not voice.
The selector is generic and it applies to the entire network, regardless of the those that don’t have a particular parameter (those will appear as black squares).“Wy is the Option shown if there is no such Sensor in my Device?”
Later A3 devices will all have the noise pollution sensor. The option was added in software, however older A3 units won’t be able to serve this data.May 31, 2017 at 12:19 pm #4476JPRuehmann
ParticipantThanks
Than it would be OK.
You´re Right in seeing the Problem.May 31, 2017 at 12:21 pm #4477SaltoUYStation
ModeratorReally great to know, Radu, Thank You!
June 12, 2017 at 10:59 am #4496Brian Levinsen
ParticipantSo I have HW 104, can I retrofit the noise sensor?
I live in an area that is close to a major airport, and there are planes flying over our area several times a day, so this would be a nice addition.June 12, 2017 at 11:31 am #4497Urs Wirthmueller
ParticipantI got a brand new A3 / HW version 103 just about a week ago. Since it should be from the latest production batch – why do I not have the latest HW version?
June 12, 2017 at 5:20 pm #4498uRADMonitor
KeymasterThe noise sensor was added in HW105 . This is not yet released, except for a single, experimental unit: https://www.uradmonitor.com/?open=8200006F&sensor=noise
We will see more of these in the future.
Units 8200006C, 6D, 6E, 70, 71 and 72 however, do have the HW105 PCB, but the sound sensor circuit is not populated. For those of you interested in enabling this functionality, it is possible to add the missing parts. I can provide guidance on that.
June 12, 2017 at 5:59 pm #4499Urs Wirthmueller
ParticipantSounds good … I got the 72. Can you please then help me to enable sound sensor circuit.
June 12, 2017 at 6:30 pm #4500Brian Levinsen
ParticipantI have 5B so am I completely out of luck, or is there any way to add the sound sensor to this one also?
June 14, 2017 at 2:13 pm #4504uRADMonitor
Keymaster@eldaria: I’m afraid not.
@urs: you need the following components:
3x Resistor SMD0805 1K
1x Resistor SMD0805 100K
2x Resistor SMD0805 1M
1x Capacitor SMD0805 100pF
1x Capacitor SMD0805 10nF
1x Capacitor SMD0805 100nF
1x Capacitor SMD0805 10uF
1x IC SMD MAX4466EXK+T
1x Electret Microphone 6×2.2mm like these: http://g03.a.alicdn.com/kf/HTB1Xj5.OVXXXXbTapXXq6xXFXXX1/Free-shipping-30PCS-6-2-2-Microphones-font-b-capacitive-b-font-electret-font-b-pickup.jpgThe components will need tweezers, soldering paste and a hot air soldering station. Careful not to damage the other parts of the board with the hot air. The circuit/pcb layout is as follows:
June 24, 2017 at 5:34 am #4554ShimmerNZ
Participant@urs: I have loads of spares from placing an order for mine (most items came in strips of 20 or more). If you haven’t yet purchased them and are considering happy to mail a set at no cost. Assuming this thing allows you to send private messages if interested.
June 25, 2017 at 9:15 am #4555uRADMonitor
Keymaster@ShimmerNZ private messaging has just been added. Thanks for the excellent suggestion!
