Home Forum Hardware uRADMonitor API for DIY units
Viewing 9 posts - 16 through 24 (of 24 total)
  • #2588
    I can only apologies for the slow progress, but it will get done since it is on the list.
    #2629
    David
    I too am interested in this but more to upload air quality/temp/humidity/pressure data if such data is on your list to include Radu?
    #2631
    Yes! We’ll have that too.
    #2634
    David
    Excellent 🙂
    I have been following the Model D build and have tried to keep the sensors as close as possible for my home build to allow the data to be comparable.
    #2638
    That makes it even better!
    #2645
    Olivier Baumgartner
    Hi
    First… excuse me for my poor english, I’m french speaking.
    I will add a suggestion for the API : Add the possibility to handle data from gamma detection (ex. PIN diode based spectrometers) with extended information like isotope identification.
    #2655
    Thanks for the idea. Do you have some samples on such data? How complex is it?
    #2657
    Olivier Baumgartner
    Hi
    Not complex… but needs more “channels” (temperature, cpm, voltage…)
    think the easier way is that the device send something like that :
    – channel name, ex. Cs137
    – activity value
    – unit, ex. Bq
    I don’t know what you plan to display on your map, if you restrict to air or if you plan to add rain (I think that in my country, rain has drop down elements from Tchernobyl).
    Best regards
    #2658
    With the increasing number of sensors, on the map you’ll be able to select the parameter of interest.
