Home Forum Support Sensor placement
  • #28372
    MATTHEW MOON
    I think the main issue now is that I cannot stay connected for very long. As mentioned before when I can get on 192..168. Etc the config page shows dns and ip not set. Is this the issue and how can I resolve please?
    #28373
    Hi Matthew,
    I think the unit should be mounted outdoors. It comes in a nice case which makes it easy to put in a place where the sun will not heat it up.
    I’m not sure what the problem is with the IP, though. Just sign it up to your Wifi network, your router/access point wll give it IP and DNS addresses automatically. You need to reboot the Smoggie to get the new settings to work.
    If you want to have a fixed IP, which is convenient if you want to routinely check the unit, then set the Smoggies MAC to a fixed IP on your access point.
    I’ve got my SMOGGIE a few weeks ago, and it was easy to set it up that way.
    It is mounted outside.
    MATTHEW MOON
    Ah cheers mate all worked like a charm!!!
    Thank you so much.
    As for housing outside, it gets very blowy on my balcony so I am gonna have to come up with an outer housing to make sure USB socket, power etc stay dry!
    Thanks again 🙂
    Hi Matthew,
    Great you got it to work! Thanks for the feedback!
