Home Forum Community Radiation vs Weather
Viewing 13 posts - 1 through 13 (of 13 total)
  • #1942
    David
    Hi All,
    I was interested in seeing how the readings from my uRAD Monitor related with the current weather conditions (wind, rain, humidity, temp, etc) so I purchased a cheap weather station off eBay and set about configuring a way to collect, store and display data from the uRAD monitor and weather station.
    The software included with the weather station was very basic so I found another program that interfaces with it called “Weather Display” which includes the ability to write observations to mysql.
    I then wrote a Python script to poll the uRad monitor every 5 minutes and add that data to another mysql table.
    Using PHP and jgraph I created a few graphs showing Rain, wind speed and temp/humidity vs CPM which you can see attached below.
    Currently I am having some issues with the weather station reporting back to it’s base station causing flat lines in the graphs. I’m not sure if this is just flat batteries or something else yet.
    Once I have this sorted I intend on adding further sensors to my array such as air quality, etc.
    Let me know what you think,
    David
    David
    Attached is Temp/Humidity graph as well as screenshot of Weather Display software.
    #1948
    David
    Here is the python script I’m using to pull data from the uRAD monitor into mysql in case anybody is interested.
    import time
    import json
    import MySQLdb
    import urllib2
    response = urllib2.urlopen('http://192.168.1.225/j')
    html=response.read()
    result = json.loads(html)
    data = result['data']['temperature']
    cpm = result['data']['cpm']
    db = MySQLdb.connect(host="localhost",user="username",passwd="password",db="temps")
    curs=db.cursor()
    try:
    	curs.execute ("INSERT INTO urad (tdate, time, temperature,cpm) VALUES (CURRENT_DATE(), NOW(), %s, %s) """, (data, cpm))
    	db.commit()
    except db.Error, e:
            print "Error %d: %s" % (e.args[0],e.args[1])
            db.rollback()
    db.close()
    #1949
    Steve
    Looks good David.
    You’re just sightly north of me. I’m #11000061
    I’ve just started gathering my uRad data into a MySQL database but display it independently to my weather station data. I’d like to incorporate my radiation data with my weather data but it exceeds my skills at present, but I’m working on it.
    I’m going to try and work with your Python script, thanks for sharing it.
    My PHP script I’m currently using is:
    <?php
        //connect to mysql db
        $con = mysql_connect("localhost","myDatabase","myPassWord") or die('Could not connect: ' . mysql_error());
        //connect to the urad database
        mysql_select_db("myDatabase, $con);
        //read the json file contents
        $jsondata = file_get_contents('http://uradmonitor-61/j');
        //convert json object to php associative array
        $data = json_decode($jsondata, true);
        //get the data
        $id = $data['data']['id'];
        $type = $data['data']['type'];
        $detector = $data['data']['detector'];
        $cpm = $data['data']['cpm'];
        $temperature = $data['data']['temperature'];
        $uptime = $data['data']['uptime'];
        $timestamp = date('Y-m-d H:i:s', time());
        //insert into mysql table
        $sql = "INSERT INTO data(id, type, detector, cpm, temperature, uptime, timestamp)
        VALUES('$id', '$type', '$detector', '$cpm', '$temperature', '$uptime', '$timestamp')";
        if(!mysql_query($sql,$con))
            die('Error : ' . mysql_error());
    So far it looks like this-> http://wotid.dyndns.org/solarhtml/radiation.php
    Regards,
    Steve
    • This reply was modified 11 years, 4 months ago by Steve. Reason: Security
    #1951
    David
    Those graphs look really nice Steve, what are you using to generate those?
    I’m using jpgraph for mine which seems to be alright but as you can see from the above I’m yet to refine them into nice looking ones.
    Apache, PHP, MYSQL are all running on a Debian VM and a cron job runs every 5 minutes with that python script to poll the data into MYSQL.
    Weather data is injected using Weather Display which runs on a Windows 7 VM.
    I noticed you are using “weewx” for yours I may have to give that a look as the less stuff I have running on the Windows 7 VM the better.
    All of this data is stored in one MYSQL database called “temps” this includes a table for uRAD, weather, bathroom, laundry and rack.
    The last three being for my home automation system to control extraction fans.
    I then use jpgraph and PHP to pull data from the tables.
    This is the PHP script for the Wind vs CPM graph. (I’m far from good with programming so it’s a bit of a mess)
    <?php // content="text/plain; charset=utf-8"
    define('__ROOT__', dirname(dirname(__FILE__)));
    require_once ('../jpgraph/jpgraph.php');
    require_once ('../jpgraph/jpgraph_line.php');
    require_once ('../jpgraph/jpgraph_error.php');
    $x_axis = array();
    $y_axis = array();
    $y1_axis = array();
    $y2_axis = array();
    $i = 0;
    $con=mysqli_connect("localhost","username","password","temps");
    // Check connection
    if (mysqli_connect_errno()) {
      echo "Failed to connect to MySQL: " . mysqli_connect_error();
    $result = mysqli_query($con,"SELECT * FROM urad ORDER BY <code>id</code> DESC LIMIT 288");
    while($row = mysqli_fetch_array($result)) {
    $x_axis[$i] =  $row["time"];
    $y_axis[$i] = $row["cpm"];
        $i++;
    $i = 0;
    $result = mysqli_query($con,"SELECT * FROM weather ORDER BY <code>datetime</code> DESC LIMIT 288");
    $y1_axis[$i] = $row["average_windspeed"];
        $i++;
    $i = 0;
    $y2_axis[$i] = $row["gust_windspeed"];
        $i++;
    mysqli_close($con);
    $graph = new Graph(1000,500);
    $graph->img->SetMargin(40,40,40,40);
    $graph->img->SetAntiAliasing();
    $graph->SetScale("textlin");
    $graph->SetShadow();
    $graph->title->Set("Red: Average Windspeed Green: Gust Windspeed Blue: CPM");
    $graph->title->SetFont(FF_FONT1,FS_BOLD);
    // Use 20% "grace" to get slightly larger scale then min/max of
    // data
    $graph->yscale->SetGrace(0);
    $p1 = new LinePlot($y_axis);
    //$p1->mark->SetType(MARK_FILLEDCIRCLE);
    //$p1->mark->SetFillColor("red");
    $p1->mark->SetWidth(2);
    $p1->SetColor("blue");
    $p1->SetCenter();
    $graph->Add($p1);
    $p2 = new LinePlot($y1_axis);
    //$p2->mark->SetType(MARK_FILLEDCIRCLE);
    //$p2->mark->SetFillColor("red");
    $p2->mark->SetWidth(2);
    $p2->SetColor("red");
    $p2->SetCenter();
    $graph->Add($p2);
    $p3 = new LinePlot($y2_axis);
    $p3->mark->SetWidth(2);
    $p3->SetColor("green");
    $p3->SetCenter();
    $graph->Add($p3);
    $graph->Stroke();
    #1952
    Steve
    My graphs are generated by Highcharts ( http://www.highcharts.com/ )
    All my monitoring is running on a Raspberry Pi Model B 2. It seems to cope with the load and it doesn’t use much power.
    I used to use a weather station like you have (WH1080) with WeeWx, but upgraded to the WH3080 for the UV and Solar Radiation data, but there’s something wrong with my sensors and the data is useless, so I don’t even display them on the current observations page.
    Steve.
    #1953
    David
    They look quite good I’ll have to have a play with them over the weekend and see what I can come up with 🙂
    I have found the reliability of the station to be a bit hit and miss so far, I was considering something like the AirPi and adding wind/rain to it but I may wait to see what which sensors Radu goes with on the new model D and start from there so that data is comparable on the global network.
    #2043
    David
    Bit of an update.
    Now have around 14,000 data points from the weather station but the radio link still has random issues and will report the same data repeatedly.
    I’m yet to figure out exactly why but am going to try moving the weather station to see if the issue is interference.
    I also intend on building another sensor array to be mounted near the uRAD monitor witch will include:
    MQ-9 – Carbon monoxide, Methane, Propane, LPG
    BMP180 – Barameteric pressure
    DHT22 – Temperature and humidity
    and possibly some more air quality sensors.
    I’m just awaiting delivery for them to begin the build.
    David
    Have started testing the new set of sensors out. Waiting on a case to put it all in and the plan is to put it as close as possible to the uRAD monitor so data can be compared.
    Attached are the last 24 hours of testing (sensors are currently inside)
    I’ve configured both the temp sensor in the BMP180 and a DHT22 temp/humidity. The DHT22 seems a bit quicker to respond to changes but both are rather close.
    #2149
    That looks great David. All the code and details would make a good topic for a dedicated blog post, would you be interested in writing one? It’s a better way to share interesting things then this forum, where the high number of topics tend to cover previous entries. I think your account has the right privileges already.
    #2151
    David
    I’d be quite happy to Radu 🙂
    I’ll see what I can put together.
    #2514
    At the end of last week (Saturday thru Monday) we got some windy and rainy weather here in Bucharest. I’ve noticed a slight increase in background radiation those days. Probably if my unit was closer to the ground the readings would have been more accurate.
    #2518
    And the readings from my weather station (Oregon Scientific RMS600) sensors for that week.
