Home Forum Software Plans for the network – data access
  • #711
    richardp61
    Hi Radu and all
    I just wanted to say a congratulation on the impressive growth of the network to by my count, around 60 units connected; I think we were just about into double digits when I got my unit earlier in the year.
    We have had some email discussions a few months back about the best ways to access the data (from one’s own unit and others) and I was just wondering if you had any further thoughts or announcements on this Radu?
    Thanks
    • This topic was modified 11 years, 8 months ago by uRADMonitor.
    #717
    Hi Richard!
    There was some very good progress with an updated firmware which opens port 80 on the unit, so you can connect to it via your browser in the local network. As soon as it is ready and it passes all stability tests, it will be released and available for update. The idea with this is to break the dependancy to the central server: in case something bad happens and the server goes down, you’ll be able to access the unit’s measurements directly in your local network, using only the Internet Browser.
    #720
    David
    Will this update be pushed out from the server or will it require local updating per unit?
    #774
    With the current hardware, OTA updates are impossible. Those interested in updating will have to do it manually. It is not complicated at all, but requires physical access to device’s PCB board and a USBAsp programmer
    (http://www.ebay.com/itm/171505112768)
    #1011
    David
    No worries.
    Is the one you have linked appropriate? If so I will order one in anticipation of the firmware update and perhaps assisting in testing the new software.
    #1012
    Yes, I’ve used a few like those myself, its just that shipping is slow for China items. There is also the one found by Mike on Amazon, see: https://www.uradmonitor.com/topic/the-new-firmware/ , shipping might be faster.
