Home Forum Support My unit has died 110000A4
  • #3031
    Hi Waheed,
    I was just thinking about your unit as I saw it offline, then I saw this post. Sorry to hear.
    Last data is from 05/30/2016 @ 11:04pm (UTC) , and the readings are fine:
    temperature: 32.5C
    cpm: 10 / 16 / 26 (normal)
    voltage on tube: 382V (normal)
    duty: 36%
    Everything looks fine. It doesn’t look like a failure. Check the network cable, the power supply and try connecting the unit to a different router. See if the LEDS (green/yellow) flash. Try connecting to your unit directly, opening its DHCP given IP in your browser (in the same LAN).
    Feel free to ask if you need help with any of the above.
