Does anyone know what size is the (female) barrel DC connector on Model A2?
Is it 5.5 x 2.1 mm, 5.5 x 2.5 mm, or another size?
I plan to order a spare passive PoE RJ45 DC adapter and my unit is in a rather inaccessible place and I don’t want to trouble it right now with near-freezing temperatures outside.
Finally I manged to replace the cables (indoor side only) for my unit. The ones that initially came with the unit were quite flimsy and I had a lot of connection issues and had to improvise something in the meanwhile. The new ones that I bought now are from a local distributor.
I also bought a Delock 82197 [Delock Cable USB Power > DC 5.5 x 2.1 mm Male 1.0 m] because I power the device straight from an APC SurgeArrest outlet (PM6U-GR) which has two USB ports. https://www.delock.com/produkt/82197/merkmale.html
Late Edit Note: Be aware that the power rating for Delock 82197 is only 2.5 watts (5VDC – 500 mA).
Privacy & Cookies Policy
Privacy Overview
