Home › Forum › Software › JSON GET-request authentication questions [SOLVED]
  • #5342
    Kotitonttu
    Hello
    I’m trying to download JSON data from the uradmonitor.com website via this:
    http://data.uradmonitor.com/api/v1/devices/5100001F/radiation
    but then I get “{“error”:”Authentification failed”}”
    I thought this was publicly available
    How can I fix this?
    #5343
    Kotitonttu
    Okay… I’m able to get a little further…
    root@pine64:~# curl -X GET -H “X-User-id:3796” -H “X-User-hash:MYHASH” http://data.uradmonitor.com/api/v1/devices/5100001F
    {“cpm”:”Radiation”,”voltage”:”Voltage”,”duty”:”Duty cycle”,”all”:”All”}
    the above response seems to be wrong…
    How can I get the same data as from my local setup?
    resource: http://192.168.1.81/j
    ###example of json response### {“data”:{ “id”:”5100001F”,”type”:”5″,”detector”:”SBM20″,”cpm”:12,”temperature”:0.00,”uptime”: 64042}}
    I just want the CPM value to be logged into my local database & I want to access the data through the cloud so that I can use the uradmonitor anywhere.
    #5361
    Kotitonttu
    curl -X GET -H “X-User-id:3796” -H “X-User-hash:SECRETHASH” http://data.uradmonitor.com/api/v1/devices/5100001F/cpm
    seems to return every CPM value that I’ve ever sent to the cloud…
    How can I get it to return the most recent one?
    #5371
    Please see detailed API description and the examples on the Dashboard, API tab.
    To get the readings you will use:
    https://data.uradmonitor.com/api/v1/devices/5100001F/cpm
    for the last 24h of “cpm” data. Instead of CPM you can use any of the sensor labels supported by your device (you already got that list):
    Finally you can call
    https://data.uradmonitor.com/api/v1/devices/5100001F/cpm/timestart/timestop
    and
    https://data.uradmonitor.com/api/v1/devices/5100001F/cpm/last
    All this is explained in the API documentation, please check it out. All these calls require X-User-id and X-User-hash in headers.
