Home Forum Hardware Clicker circuit for 3 V driven system
  • #29337
    Hi Ghosh,
    Can you show what the circuit looks now?
    I’m happy to help you out, but I need to know from where we’re starting.
    R_A_Ghosh
    Attached schematic is driven by 3V or two AAA batteries. Trying to interface a buzzer through a transistor switch from gm tube pulse but buzzer output is feeble.
    Getting proper counts though.
    #29351
    OK, if I understood you right, you want to connect a passive unpolarized buzzer to the “pulse output” of your circuit diagram, correct?
    First, you need to test if the buzzer is loud enough if you just feed it with the 2 batteries power (3 volts).
    If it is, put that buzzer instead of R3 and you are good to go.
    If not, you’ll need a second transistor stage that inverts the “pulse output” via a 10k resistor and an additional NPN transistor. Connect the buzzer between the collectors of the two transistors. That will almost double the voltage across the buzzer.
    I do not really like that HV generation circuit, since it produces unregulated HV. That will lead to varying sensitivity and spurious clicks.
    Do you have an oscillscope to take measurements?
