Home Forum Support Changing the coordinates
Viewing 12 posts - 16 through 27 (of 27 total)
  • #6034
    edodd55
    I have 2 units in China when they are now both in Australia, could you explain how to correct this?
    #6048
    HB3XPA
    Coordinates are cool now, but still got the chinese flag.
    #6065
    Klug
    CN flag too for mine 8-/
    #6067
    Jerry Xia
    After correcting the coordinates for my A3 (Unit 820000E5), it is displayed in the right place on the map, but still under Chinese flag – should be a Polish flag. Fix it, pls.
    #6069
    @edodd55 , flags changed for both units, 820000F4 and 820000F5,
    https://www.uradmonitor.com/tools/dashboard-04/?open=820000F4
    @florian_gutzwiller_hb3xpa
    Flag changed.
    @david94
    changed, Thanks!
    @jerry
    , your unit now shows the correct flag.
    BTW guys, the flag edit option will be added to the dashboard soon. The idea was that at first the location would be detected by IP, totally inaccurate but useful for a plug and play solution to have it on map the easy way. Also the country was generally detected 100% correct. Then you would be able to use the dashboard to adjust it further. But it seems it would be better to offer the country editing option too.
    So we’ll have that soon. Feel free to send in feedback regarding your units. You’re using them for some time now.
    Thanks!
    #6134
    andy_godber
    I have that problem as well, even though the coordinates are set correctly for GB.
    unit 82000096
    #6135
    Fixed! Thanks
    #6655
    Johan
    My unit 16000025 displays the Romanian flag for some reason. My existing unit 1100005B shows the correct NL flag. Can it be changed?
    #6662
    Hi Johan, flag changed!
    #6910
    edodd55
    Thanks Radu, that was easy to do after I moved house.
    The old place next to the winery had a lot of air pollution during the vintage.
    Currently we have bad air because of bushfire smoke across the area, and I hope that my new place shows better values most of the time.
    #7034
    Sounds good, thanks!
    #28738
    liviu.andreescu
    Hi!
    Trying to change my Smoggie’s latitude and longitude (with Google map coordinates) in the dashboard, but despite the fields being green (same IP) the changes do not seem to get saved. (Same with indoor/outdoor status.)
