- This topic has 17 replies, 5 voices, and was last updated 7 years, 11 months ago by
April 10, 2018 at 10:33 am #5712
costo
ParticipantSince some time it looks like the whole project is about anything except monitoring radiation.
When I joined more than 3 years ago, I thought this project was about monitoring radio-active radiation in the environment. Now when you open the website and look at the map, you can find radiation at the bottom of the menu, needing extra interaction to display the radiation. The default map shows you a worldwide map of the unit’s temperature.
This is insane, it is so senseless to display the (internal) temperature of all the units in the world like this is the most important thing there is.
F.i. my unit is mounted at about one meter high on the outside of my house. Early in the morning the temperature rises to its highest point of the day because the sun is shining on the black enclosure of the unit.I’m sorry to say but it looks like radhoo’s and (t)his project has sold out to the fake environmental/global-warming movement. (That’s where the money is)
April 10, 2018 at 5:53 pm #5713uRADMonitor
KeymasterHello Costo, thanks for the message, yet I must admit I have little success in understanding what troubles you: you can still open the map with radiation selected by default: http://uradmonitor.com/?sensor=cpm
The model A is still part of the portfolio, being one of the best products designed so far. So is the A3, which continues the radiation monitoring legacy.
Pollution affects more people (about 7million/year worldwide and about half a million per year in Europe) than radiation related incidents did during history. And the numbers are increasing considering where our society and way of living is going.
So the project tries to help more people, adding more sensors and leveraging on the mature IOT infrastructure developed so far. What’s wrong with that?
April 10, 2018 at 7:57 pm #5715costo
ParticipantHi Radhoo, my problem is the default opening of the total useless temperature measurements. My sensor is measuring the internal temperature of the unit, that only tells something about the functioning of the device. It says nothing about the environment and has nothing to do with pollution. If you try to convince me that temperature and pollution are in any way correlated with each other, I strongly disagree with you.
Also if you try to convince me that CarbonDioxide and pollution are the same , I strongly disagree. CO2 is nessecary food for plants, trees fruits etc.For me personal I do not care how the website uradmonitor.com looks like, I rarely visit the place. I publish and store my sensordata locally with a RaspberryPi and the opensource homeautomation program Domoticz (Domoticz.com). Sometimes I tell someone who is interested in monitoring hazardous pollution about the site uradmonitor.com. Then they get to see by default the temperature map. I think that is unrealistic.
April 17, 2018 at 3:50 pm #5722costo
ParticipantRadhoo, it does not make sense that you say people can open the website with: http://uradmonitor.com/?sensor=cpm because the same is true for https://www.uradmonitor.com/?sensor=temp.
You are for some reason insisting on having the temperature as the default sensor. That makes no sense because all the older units measure the temperature inside the mega328 chip, at least my unit does it that way. (Are you being payed for pushing the temperature on top or is something offered to you in the future ?)
All the units that have an internal temperature sensor will produce inaccurate temperature data so that is data that have nothing to do with the environmentI am dissappointed that you push fake data and hide the real data (radiation) at the bottom of the menu.
April 18, 2018 at 7:24 pm #5725uRADMonitor
KeymasterHello @Wolferl ,
People who stumble across your website without knowledge about that project and its abilites, should see something more meaningful, like radiation (since all sensors have at least that).
As far as temperature goes, it would be nice to have a flag that shows if the unit is mounted indoors or outdoors.Thanks for your suggestions. I will see what I can do.
Hello @costo ,
You must be joking.
Sorry, I don’t do that.
Temperature is simply the first item in the list of sensors. That’s it. The frontend shows the list in order.
The internal temperature is being compensated and should be very close to the external, real temperature, please check it.April 26, 2018 at 6:39 am #5732uRADMonitor
KeymasterHello, I am happy to report that Radiation has been selected as default view. There is also a label under the map, to provide more information on what sensor is presented.
Please test and provide some feedback.
April 28, 2018 at 5:48 pm #5773uRADMonitor
KeymasterThank you Wolferl,
What other feature would you like to see on the front page?
July 12, 2018 at 10:19 pm #5938Samuel Wantman
ParticipantI’m now seeing radiation as the default and that is great. But my problem is that if this project is truly a way to monitor the environment then the information has to be accurate. If it isn’t, it totally defeats the purpose of the map and the project. I’ve often scanned the map looking for radiation hot spots. I find many suspicious clusters of units which I suspect are not really environmental readings. Several are in Romania, which I suspect is Radu testing units. Others are in Hong Kong, which I’m guessing is where they are manufactured. There is also a unit in Monaco. Should I be concerned? I don’t know because I have been fooled by other high readings. So I would suggest the following: Have a flag for each thing being monitored that can be set if the unit is actually monitoring the environment. If it isn’t, exclude it from the map. So, for example, my unit monitors radiation, but the temperature is the ambient temperature inside the unit. So the environmental flag for my radiation reading would be set on, and the flag for temperature would be set off. The defaults for all new units should be off. Part of the process of registering a unit would be to have the owner confirm that the unit is installed for public environmental monitoring. Next, there should be a way to contact anyone with a consistently high environmental reading to find out the cause of the reading. Perhaps this could be done with an automated e-mail. If there are several contacts without the owner confirming that the readings are truly environmental readings, the unit would be flagged as suspicious or malfunctioning. There should be a checkbox for showing or hiding these suspicious units. And I also suggest that offline units should not be showing in the default case. Having them appear only makes the data inaccurate. Bad data destroys warning systems. If there is constantly data that would cause alarm, people learn to ignore the data. Then, when there really is a danger, nobody pays attention. Please fix this.
July 13, 2018 at 9:56 am #5943Yves Dubois
ParticipantHi,
I am the unit in Monaco and unfortunately for some time the geiger ware indicating crazy readings.
The whole story is here https://www.uradmonitor.com/topic/a3-radiation-reading/#post-5941July 13, 2018 at 4:40 pm #5950uRADMonitor
KeymasterJuly 13, 2018 at 8:53 pm #5951Samuel Wantman
ParticipantThat is great Radu. I have one more suggestion after reading the thread about Monaco. Allow both users and system administrators the ability to wipe out bad data history from the database when things go awry or whenever they know the data is bad.
October 3, 2018 at 9:28 pm #6090uRADMonitor
Keymaster@samwantman-net , that would be an excellent feature to have. Not easy to implement but I will look on a way to allow users to mark/flag their data.
