Home Forum Community Abnormal readings on 11000036
Viewing 8 posts - 1 through 8 (of 8 total)
  • #1899
    Paul.P
    Hi Radu I have a screen grab of the same unit from 18 April and I thought it was a test or unit malfunction but it did settled down soon after .
    Dave
    I’ve also been watching unit 11000089 in Columbus, OH, USA. I think it has some fairly high readings too — but not near as high as Norway.
    #1921
    Paul.P
    Greetings all here is some more data from unit 11000038.
    Has anyone got any ideas whats going on over there?
    • This reply was modified 10 years, 10 months ago by Paul.P.
    #1930
    I got no reply from the owner of 11000036 for more information.
    All other station parameters show normal readings:
    temperature:
    https://www.uradmonitor.com/data/0.1/public.php?id=11000036&param=temp1
    voltage on tube:
    https://www.uradmonitor.com/data/0.1/public.php?id=11000036&param=vol
    duty cycle:
    https://www.uradmonitor.com/data/0.1/public.php?id=11000036&param=duty
    #1937
    uaneme
    Isn’t this an area where Rolls-Royce is building nuclear submarine engines?
    Maybe it is someone who works on a nuclear submarine who measures the radiation of his laundry? It’s not funny i know, these levels can’t be healthy.
    I hope the person who set up this monitor can give us some information of what is causing these levels.
    Is there a way to add notes nest to the data? or to blocks of data?
    Something like selecting a spike and add a note that explains the data.
    In the long run then you have a memory of some events that can help to explain other events.
    #1938
    Dave
    Given that an approximate dose for a chest x-ray is 50 uSv, then with average readings of 7 uSv/hr, that’s like getting a chest x-ray every 8 hours! That can’t be healthy.
    #1939
    uaneme
    I just had a look on Google street view, there seems to be no heavy industry in that area (if it is the correct spot where the monitor is) A few houses and a graveyard a little up the street and a little further a healthcenter. It seems a very nice neighborhood if you don’t mind the radiation levels…
