My keeps losing its WiFi connection. It usually works for a few days and then drops it again. Re-booting the unit fixes the problem but then again – for just a few days.
I think you need to boost the Wifi signal, by placing the unit closer to your internet router. The Wifi antenna is internal, so compared to previous versions, the range is reduced.
I can no longer access my unit. I shows on my list of networks, I can get connected to the uradmonitor network using the password , but I cannot see the settings if I try to access the unit with my browser.
Any help to it?
I have tried to connect to my industrial unit using the coolterm software on a Windows 10 laptopt – without no luck.
The only port I can see is com1. I am unable to enter any text after connecting via com1. Do I have to install a special driver for the units usb port?
I did try using the driver as described – no success. I just says the driver is pre-installed. But then if I connect the uRadMonitor device there is still only the non-functioning COM1 Port.
This website uses cookies to improve your experience. We'll assume you're ok with this, but you can opt-out if you wish. Cookie settingsACCEPT
Privacy & Cookies Policy
Privacy Overview
This website uses cookies to improve your experience while you navigate through the website. Out of these cookies, the cookies that are categorized as necessary are stored on your browser as they are essential for the working of basic functionalities of the website. We also use third-party cookies that help us analyze and understand how you use this website. These cookies will be stored in your browser only with your consent. You also have the option to opt-out of these cookies. But opting out of some of these cookies may have an effect on your browsing experience.
Necessary cookies are absolutely essential for the website to function properly. This category only includes cookies that ensures basic functionalities and security features of the website. These cookies do not store any personal information.
Any cookies that may not be particularly necessary for the website to function and is used specifically to collect user personal data via analytics, ads, other embedded contents are termed as non-necessary cookies. It is mandatory to procure user consent prior to running these cookies on your website.
