- This topic has 1 reply, 2 voices, and was last updated 9 years ago by
October 31, 2017 at 10:00 pm #5127
Alexander
ParticipantHello,
could someone point me to the description of how to upload data to uRadMon servers?
I have DIY kit installed, connected to my Linux server.
I got reading every minute and I am happy to share that with the community.However it is not clear of how to UPLOAD data – all manuals I managed to find here were about DOWNLOADING.
in uradMon.cpp (350) I foundsprintf_P(ethParams, PSTR(ID_TIME_SECONDS"/%lu/"ID_VERSION_HW"/%u/"ID_VERSION_SW"/%u/" ID_GEIGER_CPM"/%lu/"ID_INVERTERVOLTAGE_VOLTS"/%u/"ID_INVERTERDUTY_PM"/%u/" ID_TEMPERATURE_CELSIUS"/%.2f/"ID_PRESSURE_PASCALS"/%lu/"ID_HUMIDITY_RH"/%.2f/"ID_TUBE"/%u"), time.getTotalSec(), (uint8_t)VER_HW, (uint8_t)VER_SW, data.getGeigerCPM(),data.getInverterVoltage(), data.getInverterDuty(), data.getTemperature(), data.getPressure(), data.getHumidity(), GEIGER_TUBE );Not very useful to be honest – I am not very good at C.
Can I use some standard POST requests? That would be ideal.
Thanks.
November 2, 2017 at 8:42 pm #5143uRADMonitor
KeymasterAbsolutely,
I was planning to write a guide on the EXP protocol and all the upload details, but with so many things on my head I didn’t get the chance. I am showing you how to do it here, and maybe if you have the time, you can contribute with a proper article on the blog.
The EXP protocol is nothing but a sequence of :
<SENSOR IDENTIFIER>/<VALUE>that allows you to concatenate readings from multiple sensors in one upload.Method: POST
Headers:
X-User-id:<number>, is your user ID as presented on the dashboard API tab.
X-User-hash:<string>, is your user KEY, again on the dashboard.
X-Device-id:<string>, this is an 8 digit hex number. On your first call, it must be 13000000 . The server will respond with a json containing {“setid”:”13000XXX”} where XXX are also hex digits. Save this to a file, and use it every time from now on, as it is your dynamically allocated ID.URL:
https://data.uradmonitor.com/api/v1/upload/exp/01/<total seconds>/0B/<counts in CPM>/10/<tube id>Call this every minute or less (once per 10minutes, etc)
The
<total seconds>can be your linux system epoch unix time, in seconds!
The<counts in CPM>is a number
The<tube id>is defined here:
https://github.com/radhoo/uradmonitor_kit1/blob/master/code/geiger/detectors.hOther EXP constants are here, should you want to add more sensors: https://github.com/radhoo/uradmonitor_kit1/blob/master/code/misc/expProtocol.h
