Home Forum Support unit (tube?) not working
  • #3667
    If the pulse counter works (touching the ends registers pulses), and there is high voltage on the 10M resistor going to the anode, than the tube is dead and you’ll need a tube replacement.
    #3668
    wanek
    thanks for the fast reply!
    it depends what do you mean by “high voltage”. with my dmm i measured 190v dc between the anode and gnd. still, the display shows 380v. please see picture.
    #3669
    wanek
    wanek
    it’s not the tube! i have replaced with a known good one, and it is the same result…
    also replaced all relevant transistors, except mpsa42, nothing.
    i suspect the high voltage generator, maybe c6, c10, c11 or L1: if i heat them with a hair dryer, in several seconds the voltage drops to 300v and the duty cycle goes up to 90%, and stays there, even after the temperature goes back to normal (20c).
    on the other (working) unit, the duty cycle goes up quickly to 90% when heated, but the voltage stays around 360v. and after it cooled down to room temperature, the duty cycle goes down to normal (60-70%).
    #3672
    check voltage before the 10M going to anode, and GND.
