Home Forum Community Station pressure conversion and small offsets
  • This topic has 2 replies, 2 voices, and was last updated 6 years ago by Sean.
  • #28514
    Sean
    Hello,
    Is it possible to convert the Station pressure to sea level pressure using a command over the USB cable ?
    Also I would like to make small offset adjustments to the Temp and Humidity using a command over the USB cable ?
    Has anybody done this ?
    Many Thanks Sean
    #28519
    Hello Sean,
    Yes, you can set linear offsets to Temp and humidity via USB . There will be a manual for that soon, as it requires a few steps to do it.
    #28521
    Sean
    Thanks Radu,
    I’m looking forward to taking a look at the manual !
    I would also like to convert to sea level pressure instead of station pressure that would be great too.
    Cheers Sean
