Home › Forum › Software › Pressure data har a very high value
  • #6901
    Terje Andersen
    Most likely a stupid question, but:
    When checking the pressure data from the A3 sensor, it provides a huge number like 102000.
    The lowest pressure measured is 870 hPa and the highest pressure is 1084 hPa, average is 1013,25 hPa.
    Do I need to convert the number 1020000 to 1020,00 or is there another way it must be calculated?
    The same goes for VOC data.
    Thanks
    #6903
    Teza
    Thank you Wolferl.
    So Guess for the ‘”voc”:463654,’ value, it need to be divided by 1000 as the range is given from 10ppm to 1000ppm?
    #6904
    Hello Teza, to understand the VOC output, please read this blog post: https://www.uradmonitor.com/metal-oxide-voc-sensors/
    Let me know if you need more info.
