- This topic has 4 replies, 2 voices, and was last updated 5 years, 4 months ago by
September 24, 2020 at 1:37 pm #28523
Ken Jamrogowicz
ParticipantI note that the ZH03A sensor shown in the specs is no longer in production and what is being sold is the ZH03B. Can I safely assume this is a drop-in replacement? I while waiting a month to get one from RO, I just bought one from China through Amazon and have it in hand.
On this subject: my failed unit is showing 850/1000/1000 ug/m3. I believe a failed laser diode will cause the unit to read full-scale on all particle sizes. As far as I can tell from available spec sheets, the full scale value should be 1000 for all particle sizes. What is the reason the PM1.0 is reading 850 instead of 1000?
Thanks
KenSeptember 25, 2020 at 12:54 am #28525Ken Jamrogowicz
ParticipantOK – answering my own question. The B unit has a bigger fan than the OEM “A” unit. The attached photo shows the old one on the left and the new one (already connected) on the right.
As it was, the OEM did not fit very well either. It was *very* difficult to get it out of the case.
To get the new one in I decided to cut off piece of the circuit board, remove two of the screws holding the fan on and file down one corner of the PM unit.
The result is shown in the last photo where some white space is left so you can see how it fits. It is quite impossible to mount the PM unit on top of the PCB, as both the -A and B versions are the same height as the enclosures. I have no idea how uRad was able to get the PM unit in there originally.
It has been running for a bit over ah hour now and looks like it will be OK.
Regards
KenNovember 4, 2020 at 2:26 pm #28560uRADMonitor
Keymasterhello Ken,
I am glad you fixed it successfully.
The PM sensor must not be mounted on top of the PCB,
instead it must go through the PCB in the designated area. Basically it fills the entire aluminium enclosure height, going through the PCB.
Here’s a picture:
November 4, 2020 at 3:00 pm #28562Ken Jamrogowicz
ParticipantYes.
But your picture is out of date. The sensor you can buy today does not fit. And whoever assembled my unit originally simply jammed the sensor on top of the board.
Modifications I show in my photos will allow using the new sensor without forcing it.
But, basically, you have a problem with the current production run.
Ken
December 6, 2020 at 8:16 pm #28593uRADMonitor
KeymasterThe picture is new on a production unit. The manufacturer produces this variant for uRADMonitor.
