Home Forum Community Formaldehyde – local data always zero
  • #6487
    You will often see the VOC AQI perfectly aligned with Formaldehyde readings. I love it, since the two sensors are using very different tech for their operation.
    #6494
    edodd55
    Tonight the sensor is reading at the maximum again, 5000 ppb (or 5 parts per million). Maybe a different sensor which has a higher maximum could be found for a newer model?
    #6500
    Sadly, this is most likely a formaldehyde sensor failure. Your unit variant uses analogue connection to sensors, so there is little we can investigate here. Newer A3’s communicate with the formaldehyde sensor via a serial connection.
    Drop me an email on support@uradmonitor.com if you want me to service it.
