Home Forum Support Dublin units ?
  • #3464
    Hello Paul! How are things going at your end?
    The issue happened because the unit’s location reverted to default , based on IP. Please go to the Dashboard and set yours to the right spot: https://www.uradmonitor.com/dashboard/
    #3468
    Paul.P
    All well this end Radu.
    My unit is 11000038 in Naas and its working like a champ no problems with the location either.The dashboard works well too. It is the 2 units that were in Dublin city that I can’t see the data .I can’t remember the unit numbers so your on your own there.
    One more thing the month option in the graph is missing …but I’m sure you have a reason for that at the moment.
    Keep up the good work and best regards to you and yours.
    P.
    #3487
    Thanks Paul, understood! I’ll take care of the overlapping units with a little update on the frontend part of things.
