Home › Forum › Software › db backup – be aware
  • #1305
    vinz
    Member
    as far as I could see on my own databases, using mysqldump to backup a database or table will write-protects it during action.
    Better ways to backup a big database are filesystem snapshot or volume manager snapshot (if you can use them)
    or the program XtraBackup which does non-locking backups for InnoDB storage.
    I found it referenced here:
    https://en.wikipedia.org/wiki/MySQL#BACKUP
    You could also replicate the database to another host and backup this.
    Vinz
    #1307
    Most likely when the cron called mysqldump backup script runs, some of the new entries are lost.
    My plan was to archieve the old data periodically and keep a smaller DB on the run. This would have helped the backup process as well, yet some time would still have been used.
    I will look on the alternatives you’ve indicated.
    Thanks!
    #1314
    vinz
    Member
    that’s it; what I wanted to say:
    You must not use mysqldump for big production databases.
    One way would be, to master-slave replicate the DB and dump the copy:
    https://dev.mysql.com/doc/refman/5.0/en/replication-howto.html
    Other way, the one I’d investigate in, would be XtraBackup.
    Btw. Radu, could you install vim, screen and htop on the dev-server? This would enlighten my commandline-feeling.
