I noticed that some folks have the formaldehyde sensor read zero when the level is … well … zero.
(for example 82000108)
Mine goes not lower than 7 ppb which is kind of an odd number.
Is there some way to make it zero?
I noticed on the spec sheet that there is supposed to be a factory zero calibration. So it should read zero, no?
7ppb is the default reading on all newer units as we switched to a different formaldehyde sensor . Please check newer ID’s, closer to yours and you will see similar readings.
Privacy & Cookies Policy
Privacy Overview
