Home Forum Hardware Add CI-21BG (SI-21BG) to KIT1 options?
  • #29908
    hexbus
    Electronics Goldmine has these on sale, and I’ve been able to get these hooked up – although, there’s no options in the source for them:
    G24780 ^ CI-21BG Russian Beta & Gamma Geiger Tube
    How easy/hard would it be to add these to the detector.h and detectors.cpp to get them to work? Right now, it’s seeing it as a SBM-20, and I know I would need to recompile.
    The only specs I can find on them are:
    Working range of Dose POWER: 50R/h
    Working Voltage: 350-450V
    Maximum registering range: 1000 Roentgen/hour
    Plateau Length/ Inclination: 100V/0.15%/V
    Current sensitivity: 0.4 – 0.7 uA/R/h
    Maximum current: 12-20 uA
    Length: 70mm
    Diameter: 10mm
    #29909
    hexbus
    Do you need help with the firmware? I can compile it for you, to include this new tube. Let me / us know.
