- This topic has 5 replies, 2 voices, and was last updated 6 years, 9 months ago by
mmx.
November 7, 2018 at 4:02 pm #6279
mmx
ParticipantHi there,
I have two issues with my A3 model (82000095), maybe they are related.
First of all, the device reboots quite often. According to the device uptime it was reset (automatically – not by me) ~20 times since the 1st of September till today (7th November). See attached screenshot of my monitoring (monitoring is done by querying the server API, not the device directly).
Second, the device is connected to my wifi but at the same time it still has its own wifi “uRADMonitor-95” running. When I first installed the device I never noticed that it kept its own SSID up and running (I’m pretty sure it didn’t). Is that intentional or is something wrong with my device?
If it’s intentional I really dislike, from a security point of view, that it shows the password of the main WIFI it’s connected to in cleartext, because it is not that hard to figure out the password for the default uRADMonitor wifi and then you are a simple step away from connecting to my private network.Kind Regards
Matthias
November 10, 2018 at 4:54 pm #6281uRADMonitor
KeymasterHi Matthias,
To prevent reboots, try to provide a stronger Wifi signal for the unit to connect to.
The default hotspot is left on intentionally, so you can re-configure it anytime you need. But I get your point. Two fixes here:
– on newer firmware, the configuration screen doesn’t show the password in clear text
– on a firmware variant you can choose an option to disable the internal hotspot, a few seconds after reboot. So it gives you the chance to reconfigure it when needed, then the hotspot is turn off.Both would require a firmware update. Not complicated at all. Interested in going this route?
November 11, 2018 at 12:07 pm #6282mmx
ParticipantHi Radu,
thanks for your reply.
In regards to the wifi, so whenever the wifi signal is lost the device reboots, didn’t know that?
Anyway, I believe the wifi signal is quite stable since the access point is roughly 5m away from the device, which sits on my balcony and there is “only” a window in between.
Maybe I can tweak the antenna a bit, my access point reports currently towards the device values for signal: -65dBm, noise: -95dBm, SNR: 30.In regards to firmware, sure, what do I need to do to update it? Is there a changelog somewhere about what else has changed?
cu
Matthias
June 18, 2019 at 6:35 pm #6621mmx
ParticipantHi Radu,
I ordered an USBasp programmer and it finally arrived and I would like to try and update the firmware. Can you provide me with the firmware you mention above with the two fixes:
– on a firmware variant you can choose an option to disable the internal hotspot, a few seconds after reboot. So it gives you the chance to reconfigure it when needed, then the hotspot is turn off.My device is 82000095.
Thanks
Matthias
June 25, 2019 at 11:41 am #6625uRADMonitor
KeymasterHello Matthias,
For requirement 2) , how many seconds do you need to have it on before it will turn off automatically? 60sec would do?
June 25, 2019 at 2:00 pm #6627mmx
ParticipantHi Radu,
yes, I think 60 seconds should be long enough.
Matthias
